SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
SOURCE: Back flare on Raypak pool heater
You will need to pull the burner tray out and clean and blow out the burners. Then you will need to pull the orfaces from the gas manifold and clean each one and blow out the gas line. Then with a mirror you will need to check the fire brick inside the burner box. Then you will need to replace anything that is damaged. Good luck.
Testimonial: "thanks for the insight. I assume that I will have to disconnect the gas line and then reconnect afterward. Appreciate your information."
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
SOURCE: raypak r266a residental pool heater sensor code
SNS means Sensor failure, Water temp. below 36°F or above 110°F
You will need to replace the temperature sensor. Here is the sensor and PC board:
http://www.inyopools.com/Products/04000000029300.htm?CS_010=29300&CS_003=905765
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
