I have Integrated webcam built-in on my Dell Inspiron 15 3567 laptop. I have Dell webcam central app to run it. This app running camera well and I can record audio and video clearly. Other add-in named Live! cam avatar creator works well. How to enable settings and effects shown in app to work? Dell webcam central version is 1.40.05.
NO OS stated, is this WINDOWS< y/n if yes, what windows
we can not guess windows versions from 1998 to 2018
XP to W10 is 99% of the post here, why not tell this.
The PC must have its DELL drivers load and correct or things fail.
my guess is this PC is corrupted in some way.
virus?
or the app from Dell is bad/wrong or corrupted, or someone loading the wrong one or verison on your PC.
Why not just go to dell.com and get it, first and load that first.
see if the software works now?
3rd google hit, btw.
http://www.dell.com/support/home/us/en/04/product-support/product/inspiron-15-3567-laptop/drivers
load the web cam drivers
then load the apps related to it next.
if confused why not ask on the dell forum for help and not here.
Fixya is NOT DELL. (not by a mile)
virus?
http://www.dell.com/support/home/us/en/0...
note it asks for the OS first. see,
get that wrong and bam you mess up the works big time.
the other trick is getting the graphic driver right.
only the full model numbers tell dell what is in the box. the PC,
what GPU chip options were fitted there day 1 new.
and more, guessing will mess this all up big time. PCs car complex
know that one simple model can have vast choices of chips and features inside.
it's not just 1 answer. ok?
see those first 7 choices
one may run and find all missing drivers.
start at the top work down.
if w10 there are more choices there.
SOURCE: HOW DO I TURN OFF AVATAR LIVE CAM VIDEO
This problem is not fixed through the settings of your Creative device but by selecting the right webcamin your messaging software.
When you install your Creative Camera it installs the physical Camera as well as a virtual Camera. So there are actually 2 (or more Camera's installed). The Avatar plays through the virtual Camera.
Whatever programme you are using (MSN or SKYPE etc) you need to select the correct video Camera.
So, for example in MSN messenger, select Tools, Audio Video Setup and select your camera from the list (make sure the Virtual camera is not selected).
To be even clearer as an example: If you are using a LiveCam Notebook Ultra 3 camera, you will see the following listed as cameras when you go to select a webcam to use within your messaging software :
Live! Cam Ultra Notebook #3 -- this is your normal camera
Live! Cam Virtual -- this us the Avatar etc camera,
Live! Cam Ultra Notebook Ultra (VFW) -- this is your widescreen camera
Just select the right one!
Fliboy
SOURCE: Dell Inspiration 1545 - Webcam wont work on live messenger
go to dell.com.... search for their toll free numbers.. call their tech support.. they will solve your problem for free.
SOURCE: new msn messenger video chat isn't working
Sorry, I cannot help with the flickering, but you shoud be able to work the webcam. Please rate me afterwards!
Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
SOURCE: Fail to connect to webcam
Greetings...
hello, regarding on your problem please check your driver installed in your laptop and see if the driver you install is compatible in your current operating system otherwise it will not recognized the webcam driver. Also please check the settings of your skype or ovoo .
Thanks
SOURCE: Audio Effects Missing from Dell Webcam Console
i think your audio drivers has not installed so first installe the audio drivers through dell audio drivers website.
