SOURCE: samsung dvd sh873 recorder with
Did you turn the power off to finish the timer recording? Timer recording doesn't work with the power on.
SOURCE: DVD recorder no longer acknowledges pre-recorded or blank DVDs
Have you tried a disc cleaner yet?
SOURCE: Wii Fit Board not working
make sure you have the board the right way around! i know it sounds silly but mine did this and all you have to do is make sure the power button is facing away from the tv! i dont know if that solves your problem but it solved mine!
SOURCE: Samsung GT B3310 wont let me video record each
This is caused by a fault in the system I had the same problem, you probably have the key volume on 0 or 7, put it from 1 to 6 and that should fix the problem,
Testimonial: "That did fix the problem Thank you"
