Question about Golf
2006 EZGO gas golf cart brake lights does not work. I replaced the micro switch and all lights and turn signals still work but no brake lights. Help
SOURCE:
SOURCE: I ned a service manual for a 1995 ezgo dcs golf
Our EZ GO golf cart will start and run except you have to hold the choke about half way out for
it to continue to run. What is wrong?
Posted on Apr 20, 2009
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
  • 34 Answers
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?func=show&file=200332&Category=100013&Page=1
Posted on Apr 21, 2010
  • 34 Answers
SOURCE: EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Posted on Apr 24, 2010
HOW TO GET THE PART NUMBER FOR THE REAR BRAKE SHOES FOR MY RUFF AND TUFF GOLF CART
E-Z-GO Golf Cart Brake Shoes - Genuine E-Z-GO Parts and Accessories
https://shop.ezgo.com > Shop > Parts > Brake Parts > Brake ShoesOEM Golf Cart Brake Shoe 4084 ' Single Shoe. Fits 1996-current E-Z-GO Golf Car and Utility Gas & Electric Vehicles. Item #: 648037. $24.70/ea. Spring- Shoe Return- LH (Blue). Used on 1996-Current E-Z-GO Gas & Electric 4/6 Passenger Shuttle, ST Express, 875, 881, 950, and Cushman Titan Vehicles; in addition to ...
Nov 30, 2017 | Cars & Trucks
Looking for wiring diagram for 1999 TXT EZGO golf cart controller?
There are a ton of them available, apparently:
https://www.google.com/search?q=1999+TXT+EZGO+golf+cart+controller&oq=1999+TXT+EZGO+golf+cart+controller&aqs=chrome..69i57.1143j0j4&sourceid=chrome&ie=UTF-8
Aug 02, 2017 | Golf
Ezgo 36 volt buggy i have 2 one in good running order other one not going now solenoid not clicking have swwapped solenoid and controller to good running cart and it works problem cart still problem
Hope it's fixed by now. If the solenoid is not clicking then one of your switches is bad or wiring. Check the key switch, forward/ reverse micro switch, and the switch in the floorboard that is connected to the gas pedal.
Apr 19, 2017 | Golf
I recently came across an ezgo golf cart I noticed I m leaking gas out of the petcock valve and was wondering if I can bypass it?
Hi, Sally I would "NOT" recommend bypassing the valve just replace it for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Product Manuals
GO Golf Cart Parts
Cartaholics Golf Cart Forum EZGO Golf Cart Repair
http://www.buggiesgonewild.com/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 09, 2016 | GAS Motorcycles
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Ez golf cart when I go up steep hill the cart loose power and smoke White smoke
Basic EZGO Golf Cart Problems And How To Fix -
www.golfcarthotrod.com > Golf Cart Repair
Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
Aug 02, 2015 | Cars & Trucks
Ez-go golf gas cart only runs when rear wheels are off the gound, why?
It has a level switch that is broken or out of adjustment
May 17, 2014 | 1993 Acura Vigor
Golf Logo
274 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
