Garden Logo
E
Eugene savage Posted on May 28, 2018
What is correct oil to use in kew1702kpower washer
1helpful
I over filled the oil and the oil was all over the honda pressure washer now what do I do
drain the oil back to the correct level and clean up the mess
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 • Psi Garden
Too much oil in pressure washer
NEVER run any motor with too much oil. You can blow the seals. Let some out to achieve the correct level. Also, verify that you are reading the dip stick correctly. Many motors you DON'T screw the dip stick in when takeing a reading. Just wipe it and set it in.
May 19, 2014 • Garden
2helpful
Needs oil change ; what is correct oil to use ?
Typically they use a 10w30 oil in the engine and a non-detergent SAE30 oil in the pump portion.
Oil type in Karcher gearbox
If you are talking about the water-pump gear box only, the correct oil type is 30W NON-Detergent oil. "ONLY"
1helpful
Dont get correct pressure. What type of oil do i
A loss of pressure on this type of washer is normally caused by failing water seals and check valves in the pump. You will need to replace both of these using a pump rebuild kit that will be available by contacting the manufacturer of your machine. The pump oil used will be 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
1helpful
What oil or gear lube goes in the pump howsing
The correct oil to use is going to be a 15w40*1, this is a special oil that is made by Karcher, any other oil is going to breakdown much faster and will cause the bearings and wobble plate to not be properly lubed. See link to purchase oil or read more.
What viscosity oil is recomended for oil change?
  • Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
1helpful
What is the correct engine oil for an xj900f
Any 10/40 oil will do, but you have to run motorcycle 10/40. Car oil will not do, unless you are stranded,etc. Always replace your crush washer, or sealing washer. Prefill your new oil filter with the new oil. Start and let run for a minute, turn off and wait for a couple of minutes to get the correct oil level. Check the oil level when the bike is straight up. Chaz Moto DC
Top Garden Experts
Jay Finke
Jay Finke
john h
