A
Art print Posted on May 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica minolta 6500 error code 3912 - Konica Minolta Office Equipment & Supplies
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Mar 03, 2019
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913914
Points
11960
Get to "Utility Menu screen"
Press the hard keys in the following order:
Stop ? 0 ? 0 ? Stop ? 0 ? 1
Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
How to Solve C 3502 error code in konica Minolta c 6100 1100 1085 6085
The C 3502 error code in Konica Minolta c 6100, 1100, 1085, and 6085 machines is related to the fusing unit. The error code indicates that the fusing unit is not heating up correctly. There are several reasons why this error code might appear, including a malfunctioning thermistor, a broken fuser heater lamp, or a damaged fuser thermostat .
A video: how to solve C 3501 3502 3503 3504 3505 3506 error in konica minolta 6500 6501 6000 7000 - YouTube
Turn off the machine and unplug it from the power source.
Remove the fusing unit from the machine.
Check the thermistor and fuser heater lamp for any damage.
Replace the damaged parts if necessary.
Reinstall the fusing unit and turn on the machine.
If the error code persists, it is recommended to contact a Konica Minolta service representative for further assistance
Konica minolta 6500 error code c-3912
Sir,
Konica minolta Bizhub C6500 error code 3912
This usually is a problem on the fuser lamps.
Also, you can check the sensors TH1, TS1 and TS2. Be shure about the dipsw 03-1 not be on, after fixing the fuser.
Error code C-C134 - konica minolta C6501 Pro - Konica Minolta Office Equipment & Supplies
Has the IPB been replaced? It may be the wrong one.
A03U H020* is for 6500/5500
A03U H0200* is for 6501/5501
1helpful
How can i do for error C6702
http://www.copytechnet.com/forums/konica-minolta/30879-konica-minolta-biz500-code-error-c-6702-a.html
guy does eventualy fix it on later pages
worth a good read
i got board half way down
a good tip with rollers {rubber not sponge} is too use white vinegar wipe it on leave it to dry
and run few some fully black sheets...prints
then it works magic
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Error code c2863
Hi, i have a konica minolta c6500, and i have a problem with error code c-6500. What happen?
11helpful
4answers
What does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
ERROR CODE C-4401 On Konica Minolta Bizhub 500
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
