After washing the dishes, there is water at the bottom of the dish washer. Why
Are we talking a lot or a little? If the unit is not draining at all then there might be something stuck in the drain pump impellor stopping it from turning at all, or stopping it running as quickly as it should so doesn't drain all the water. Is the drain outlet too high? This can cause the drain pump to struggle to reach the head height, also, water can run back from the drain pipework if blockage or height too high
SOURCE: dishwasher will not drain water out
if plumbed in under the sink, check the spigot the drain hose goes to is not blocked - a common problem. if on drain you should be able to hear the drain pump working. if you hear a faint humming noise instead, then there is probably a foreign object stuck in pump. also check for blockage in the drain hose
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
SOURCE: dishwasher issue
Have had this problem twice on my DWI614. First time engineer came out and I watched what he did and asked questions. He removed panel at bottom of dishwasher (2 screws) after removing facia panel from kitchen as it is a built in dishwasher. To the right is the drain pump. Remove 1 retaining screw and hose retaining clip. Ease out the drain pump and make sure to have some cloth beneath as residual water will flush out. Before I did this the second time I removed as much water from inside with a small cup first. Both times I had blockages in the drain pump. First was a piece of glass and second some food. I also pulled the drain pipe forward and blew through to make sure path to sink was clear. Clear out and reassemble. Start a simple program before putting the front back panel back on and you can touch the drain opump and feel it working as the water drains properly. That was my fix both times, good luck.
SOURCE: hotpoint dish washer aquarius
I had the same problem with my Hotpoint Aquarius the eco and fast light flashing, it would go through the pre wash cycle and stop.
I cleaned the filters etc; and it still didn’t work.
I turned the machine off and unplugged it at the mains,
I drained all the water, turned the machine on the side and took the bottom off, I removed the drain pump off the bottom (this was held on with a single screw after taking the screw out slightly turn it to one side as its like a bayonet fit on a light bulb also remove the wire connection and a rubber drain pipe)
Once the pump was removed I could clearly see the impellor it was very tight and I couldn’t spin it after a closer examination I could see a foreign object jamming it I removed this with a pair of tweezers, replaced the pump and put it all back together and it now works perfectly.
I hope this can be of some help.
Peter.
SOURCE: Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
