Boating Logo
L
Leslie Sutcliffe Posted on May 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you know if a fuse is blown in your pontoon tracker boat
Suntracker pontoon boat ignite alarm won't shut off, oil is fine, motor not running hot. How do you check to see if a fuse is blown
David Bugden
Level 3:
Master:
  • Master 431 Answers
  • Posted on Jun 04, 2018
David Bugden
Master
Level 3:
Master:
Answers
431
Questions
Helped
132716
Points
1217
On the engine itself is a series of fuses , pull them out one at a time and look. But a fuse shouldn't cause the alarm to go . Blown fuse means no power , no power means no alarm. Never heard of an ignite alarm might that be a gas vapour alarm ... find out where the sensor is
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on Jun 09, 2009
SOURCE: Assembeling the Cimerron Pontoon Boat
I have a similar boat, but it's been a year or so since I used it. Here's what I remember.
Lay it all out first. It's very confusing until you get a visual. The seat rests on two bars. These bars span the two pontoons. I believe they use pins, rather than bolts to secure it. You probably have a basket and maybe a trolling motor mount. Get rid of the mount, unless you plan on using it. If you do, it attaches to the rear basket. The basket mounts to the back of the chair and rear bar with bolts.
Next, the leg holders slide in and there should be pins to hold them in place for the right distance. If there is a stand up plate and a casting bar, you're on your own on how to attach them. Obviously they go in the front, but I have no idea how they are attached.
Mine had an anchor, but this was a huge hassle. Much easier to pull to shore than park in the water.
There is probably a mesh type piece that fits under or around your seat with bungies or hooks. It may have a fish measure on it. If it does, that goes to the front.
The oars are merely pinned in at a comfortable spots. There should be oar "stops," that slide over your oars. Again, you have to adjust the length to how long your arms are. They don't slide too easily. And, they are needed so your oars don't slide off into the water.
The side bars should have a hump to rest the pontoons on. Buy a double pump and save some time, (or an electric pump). The following is the most important fact of all, You have two bladders in each pontoon. Inflate them BOTH. Air up one from the front, then the other from the rear, back and forth until the pontoon is ready to burst. This prevents a disaster. If one deflates or is punctured, the other one has enough air to support you to shore. Strap them on and you're ready to go. And I would suggest a practice run in calm water first. They are a little awkward at first. Good luck
Anonymous
  • 17 Answers
  • Posted on Jun 17, 2009
SOURCE: Assembly of a Cimarron Pontoon Boat
Anonymous
  • Posted on Jun 23, 2009
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Anonymous
  • 302 Answers
  • Posted on Oct 08, 2009
SOURCE: MOTOR SIT TOO LOW IN THE WATER ON PONTOON BOAT
you need to trim the motor by adjusting it so it is more vertical. It must be angled down into the water too much now and so it is pulling itself deeper in the water,
Anonymous
  • 3 Answers
  • Posted on Jun 14, 2010
SOURCE: My 30 ft. aluminum pontoons on my 1987 pontoon have holes!
Clean and use marine JB Weld on the holes. If entire surface is pitted badly, fill with Jb,sand with 300 grit entire pontoons, clean with acetone, paint with self etching primer and paint with acrylic enamel paint (automotive), followed by 2 coats of clear. I used silver gray metallic on my 24 ft. Grumman over 5 yrs. ago and it still looks great! Easier to clean than aluminum too. Just coat it a couple times a yr. with spray wax! USSGSPOT
My 2007 Avalon pontoon boat stalls out I have two lights next to key green and red red light comes on and alarm goes off then stalls out
Not knowing the engine manufacturer and horsepower it is still one of two items. Most of today's engines have an automatic oil feed if it is a two-stroke engine. The four-strokes have something similar, except it deals with maintaining a constant oil pressure for the engine and recognizes a low oil condition as well. Another potential issue is a restricted fuel supply going to the engine. Larger engines obviously, require more fuel. An air leak into the fuel line or a fuel restriction between the fuel tank and the engine can also cause alarms to activate.
Oct 02, 2019 • Boating
I have a 03 Sun Tracker pontoon & Merc 60 my throttle trim will lower motor but not raise it.It works fine from motor ,up & down okAlso just had voltage reg. replaced and tach stopped working .Help
Time to just go threw all the wiring. You have a boat. It's on the water or not. On the water electrolysis kicks in 1000%. On land corrosion set in. Check and clean the wire plugs, replace if necessary. Replace ground point connectors. Add wire if necessary. Just a note. When I do boats, I solder all connections and use silicone shrink wrap on the wires.
Jul 01, 2015 • Boating
Why won't my Sun Tracker Mercury 60 hp pontoon run?
Need some more info to answer your question. Will the motor not turn over at all or will it turn over and just not crank up?
Aug 19, 2017 • Boating
Evinrude 40hp outboard
First, the over heating alarm is for YOU to shut the motor down...
Replace the water pump assembly..(have a different mechanic do it!!!!!!!!!!!!!!)... they are NOT all created equal!!
May 17, 2017 • Boating
Suntracker pontoon won't start and trim won't work
Trim want work ,,want start,, no power
1helpful
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
1helpful
2answers
In the control box of an evinrude 115 vro v4 is an alarm why does it go off every 15-20 min when the motor running
The warning horn on a V.R.O. system ( variable ratio oilier) warns you of three problems. (1) LOW OIL. means the remote oil tank in the boat is near empty or empty(2) NO OIL. means there is no oil getting to the V.R.O. .problem is, clogged line or the diaphragm in the V.R.O is blown.(3) OVERHEAT. means the engine is overheating. The V.R.O is you lift and pressure pump for fuel and oil. plus it mixes the oil and gas to proper ratio. Three warning, three senders. LOW OIL sender is in the remote oil tank in your boat. NO OIL sender is in the V.R.O.. and the OVERHEAT sender is on one or both cylinder heads of a the engine depending on the year model
Sep 02, 2009 • Boating
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
