Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
SOURCE: Hot start problem w/Subaru
I just went through this same issue and it turned out to be the engine cooling sensor, a $50 part.
SOURCE: Harley Davidson will not start
you say at times its fireing. sounds like ignition problems. does it have points? if so they may me worn out. I have an 87 sportster evo that has points in it.
SOURCE: 93 katana 600 wont start
Take one of the plugs out and hold it against the head while the engine cranks. You should get decent spark. If not, you have an ignition problem. If it gets decent spark, try spraying some starting fluid into the air cleaner box. If the engine starts up and runs for a couple seconds, you have a fuel delivery problem.
SOURCE: can't keep running seems to flood out 1978/79 kawasaki
seems your fuel to air mixture is wrong
SOURCE: 97 kawasaki ZX11D that will not stay running without the choke on
Try to blow out the jets in the carburtor, the pilot and main jet.
Check too the float level.
