Dean,
First set the engine rpm as company recommended.. i.e.to keep maintain hydraulic pump pressure in the system,and if a short arises in the valve solenoid , this makes to remain close of the hydraulic pump valve ports and this makes to regret flow of oil to hydraulic motors to the wheels..
To rectify this problem
Remove defected solenoid valve with new....
with regards,
SOURCE: john deere 250 skid loader - purchased new in late
Apparently you have a short in the starting circuit. I would try disconnecting the start wire from the solenoid, and see if it still blows fuse. If it does it's in the control circuit. If not it's the starter solenoid.
There should be an operator present switch under the seat, that sometimes short out from an accumulation of dirt and debris that get moist.There is also a neutral safety switch and/or relays.
SOURCE: Is it a big job to replace the brakes on a john Deere 250 skid steer
check with the service dealer
most skid steer loaders do not have brakes in the normal sense but have valves that lock the hydraulic fluid in the drive motors and so prevent them from turning making them brakes
SOURCE: John Deere la110 parking brake mechanism locked up. Won't disengage when I depress brake pedal.
try this link might help you out.
John Deere la110 parking brake mechanism locked up Google Search
