Exercise & Fitness Logo
Jan Jones Posted on May 24, 2018
My Kettler Advance giro display says the automatic break is working but there is no tension when I paddle. How can I fix this please?
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on May 04, 2012
SOURCE: Is it possible to change the unit of distance and
Dear Sir:
Go under the display board, and we the point from some pencil, introduce in the small orifice, reset and you will have the change km vs mls or viceversa.
sincereLY. God bless you
Kettler Advantage Giro P Upright Exercise Bike. Not used for a year and dashboard is now totally dead.
Get a Multimeter and check that you have output voltage from the power adapter.
Also make and reconnect the connections that are under the control panel. I wondered if the control had a back up battery, but there is no mention.
https://cdn.sweatband.com/upload/multimedia/Kettler%20Giro%20P%20Advantage%20Exercise%20Bike%20User%20Manual.pdf
Kettler Toronto treadmill - The display says Safety and the treadmill wont work. The safety key is not unplugged.
Question moved from MISC.
I live in Toronto!
Try removing the key and reinsert it.
The KETTLER treadmill has an emergency stop mechanism for
your safety. Before starting your workout, fasten the cord of the
safety key to your clothing. If the treadmill has been shut down
by removing the safety key, restart it by reinserting the key. An
automatic restart of the treadmill belt does not occur. Further
instructions concerning the handling of the safety cut-out can be
found in the operating instructions for the training computer.
https://manuall.co.uk/kettler-toronto-treadmill/
Lcd display faulty kettler ex1
Please call your local Kettler bike dealer for assistance
Recently assembled and tried bike. There seems to be a catch/hitch in the rotation when pedal at bottom. It should be smooth. What could be wrong and how to fix?
It's probably the bottom bracket bearing. Exercise bikes typically have really, really cheap bearings in them. I have the same problem on my Horizon M4 with a lot of bearing chatter when doing standing high resistance.
I have Kettler Paso 309 exercise pbike hat hasn't been plugged in for a while. Now it just beeps and flashes at the display. How can I fix it?
Dear Sir:
Execute maintenance according with the instruction manual guide.
If you do not have ins.manual download for free:www.fitness.manualsonline.com or www.iconservice.com
sincerely. God bless you.
Is it possible to change the unit of distance and speed from km to miles on a Kettler Giro GT?
Dear Sir:
1helpful
2answers
My Kettler cross trainer Mondeo gives me program error E2 on the display. Kettler has cleverly hidden any information about what this actually means (so I can fix it). Thanks for any help you can...
E-2 FAULTS ARE PROBABLY DUE TO A FAULTY CONNECTION BETWEEN THE CONNECTING PLUGS-MINE WAS,I CHANGED A LEAD IN THE END AND SOLVED THE PROBLEM.PLEASE SEE MY POST ON THIS SITE ON THIS MATTER. MARK DAVIES
I am having problems with the tension adjuster on Kettler favorit on the left arm. Every time I adjust the tension to increase it, the tension grip slips back to the original lower position so I get an...
The tension adjusting mechanism in all intensive purposes has worn out and will need to be replaced. Since I don't know where it was purchased either in USA , Canada or the U.K.
[email protected]
Tel: 01527 591901
KETTLER® USA 1355 London Bridge Rd Virginia Beach, VA 23453 USA
Phone # 757.427.2400 Fax# 757.427.0183 e:mail:[email protected]
KETTLER® CANADA PO BOX 171 HASTINGS, ON K0L 1Y0 CANADA
Phone # 613.475.3300 Fax# 613.475.3395 e:mail:[email protected]
Top Kettler Exercise & Fitness Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Ngoro
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
