E2 Error usually indicates that the treadmill is overloaded and applies to various models like TR150, TRX1000 and TR 200. To fix this problem, check if your treadmill motor is overheating. Signs of an overheated motor include; grinding noise, motor produces a burning smell and inconsistent operation speeds.
Reddit · r/fixit3 comments · 4 years ago
Hi i have a reebok one gt30 treadmill bought in 2016. Recently at ... Start googling error codes and find out what E2 means. Upvote 2
Error E2 on a Weslo WLTL97540 treadmill usually means that there is a problem with the incline motor. To resolve the issue, try the following steps:
Unplug the treadmill from the electrical outlet.
Locate the incline motor and check for any visible damage or debris.
Clean the incline motor and surrounding area.
Reconnect the power and attempt to raise the incline.
If the error persists, you may need to replace the incline motor.
If you are not comfortable performing these steps or if the error persists after trying these steps, consider contacting a professional repair service.
The error code E2 is indicating that the console is not receiving any information from the reed switch or optic sensor. This is because the treadmill belt is not turning. If the motor would run you would lose the E2 error.Oct 31, 2007
The True600, 700, 725 and 750 seriestreadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
The error messages that may be displayed by the built-in diagnostics are as follows:
E1:INCLINE
This means that the incline is moving when it has not been commanded to.
E1:MINIMUM
This is a minimum incline calibrating error that can be cleared by calibrating the incline.
E1:RANGE
This means the difference between the treadmills zero position and maximum incline is not sufficient.
E1:STALL
This means that the incline is not moving when it has been commanded to.
E2:OVERSPEED
This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
E2:CAL
This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
E3:EEPROM
This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
E5:SENSOR
This error occurs when there is no speed or RPM feedback detected from speed sensor.
The service messages that may be displayed by the built-in maintenance reminders are as follows:
S1:LUBE
This service message displays when it is time for inspection of the deck lubrication system.
S2:CLEAN
This service message displays every 500 miles and is your prompt to clean the treadmill.
S3:MOTOR
This service message displays every 2500 hours and is your prompt to check the motor brushes.
This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
