Https://sites.google.com/site/dyiu22/home/noma
Quoting from web link:
NOMA
125V AC / 60 Hz
OUTDOOR DIGITAL BLOCK HEATER TIMER
052-8835-2
Instructions
Plug timer into grounded outlet
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.
To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.
To Connect/Operate the Timer: Plug device in to the timer and turn the device on.
To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above.
To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm.
Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
NOMA Dennis
Testimonial: "Hi Dennis Thanks so much for your help on this. Really helpful."
For a fee, an expert will speak with you over the phone while you work on a timer or any other do-it-yourself project.
https://www.fixya.com/support/ Dordle
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
SOURCE: instructions for NOMA N1507 timer for programming -pls.
N1507 manual:
http://waterheatertimer.org/pdf/N1507-programmable-outdoor-timer-manual.pdf
Add a comment and let me know if these instructions are accurate
SOURCE: i lost my instruction on how to programe my noma
Noma is Woods timers.
See all Woods timers and manuals
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment any time
Your timer could be Woods/Noma N1502
http://waterheatertimer.org/pdf/Woods-N1502-manual-english.pdf
Coleman 2001
http://waterheatertimer.org/pdf/Woods-2001-49647.pdf
Woods 13660
http://waterheatertimer.org/pdf/Woods-13660.pdf
Woods 59730 yard stake:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Coleman/Woods 13547 yard stake
http://waterheatertimer.org/pdf/Woods-13547.pdf
SOURCE: i have a noma outdoor digital timer, model n1502.
Link below has photo of timer to confirm correct timer.
Manual and other information also show about timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: Require instruction how to program
I show Everflourish EMT 757
Open following link to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
