Question about Riccar Sewing Machines
Riccar 525 - makes a birring noise when I press foot pedal but the needle does not go up and down. I can turn dial at right hand side ok.
  • Riccar Master
  • 12,730 Answers
Sounds like the motor is trying to run but the other machine parts are not moving. If your machine is an older mechanical (not computerized), then it's very possible the machine has seized due to lack of regular cleaning and oiling. Avoid trying to run the machine in this condition as it can damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Posted on May 22, 2018
SOURCE:
SOURCE: foot pedal and thread guide
Same thing happened to my CE-200. It would only stitch one stitch at a time or else it would run full speed. My husband made an adjustment through a small hole on the back of the pedal and it now works much better. The adjustment hole apparently allows you to set the sensitivity of the electronics inside the pedal. He turned it slightly toward the + direction. It took a couple of small adjustments to get it to work nearly normal again.
rbwinter@wbsnet.org
Posted on Jul 14, 2008
  • 166 Answers
SOURCE: my machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Posted on Jan 02, 2009
  • 323 Answers
SOURCE: My Singer Quantum CXL seems to be jammed
Go to this site
http://www.singerco.com/support/us_warranty.html
search for a Service Center in your state, call them for how to send in the machine and how much it will cost for repair.
sewman7
Posted on May 05, 2009
  • 11 Answers
SOURCE: janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Posted on Jun 16, 2009
  • 5 Answers
SOURCE: The needle constantly breaks while embroidering.
My foot does this with different thickness of fabrics, it will make the foot land in different, areas, sometimes making the needle hit the foot. Always check needle position before you start embroidering. once your hoop is ready, check the clearance. I often have to use a small roll of non slip material under the foot handle, the one used to bring the foot down. And I use this to adjust the needle postition so it will always land in the middle of the embroidery foot. There is also a way to adjust the height of the needle arm but that's too complicated to get into here and I've never personally tried it.
Posted on Oct 20, 2009
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Janome hello kitty 525 won't feed fabric or needle does not move up and down. Everything seem to be thread correctly and clean.
Hi Thi: make sure the machine is not set to wind the bobbin. Turn the handwheel towards you and see if the needle moves. You may have a belt that has come off. Does the machine make noise like the motor is running when you press the foot control?
Sep 02, 2013 | Janome Sewing Machines
Need to know how to thread a 550 super stretch Riccar sewing machine?
  • Unthread the machine.
  • Raise the presser foot.
  • Turn the handwheel until the take-up lever is at it's highest position.
  • Set the upper tension dial/knob to 5.
    The threading path is as follows:
  • From the spool around the top guide, down through the right slot, up the left slot, through the eye of the take-up lever from right to left, down through the guide(s), through the needle from front to back.
Nov 09, 2010 | Riccar Sewing Machines
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Riccar 9600, no manual, how do we thread it?
If I remember it is reel of thread on the reel pin, make sure the presser foot is up and takeup lever at the top, take the thread to the left and over the top cotton guide, straight down through the tension disc and down to the larger guide, round the right and take the thread back up the left hand side, through the takeup lever right to left and follow the guides all the way down to the needle, thread needle front to back.
Mar 28, 2010 | Sewing Machines
Won't sew when foot pedal is pressed
foot pedals do fail and possibly your s has .
Oct 31, 2017 | Kenmore Sewing Machines
No matter how hard I press down on the foot pedal my needle speed is super slow. The needle position indicator sometimes shows up when the needle is down and the needle continues it slow speed even when my...
is the machine easy to turn by handwheel? if not it may be seizing and needs servicing.
if the machine is free to turn by hand it sounds like your foot control is in need of repair or replacement - see a tech.
scott.
Jul 20, 2009 | PfaFF Sewing Machines
Sewing Machines Logo
43 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Tom Chichester
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
