SOURCE: Dishwasher not getting water into spray arm, so no clean dishes
two possibilities: open door when in use. check if water is coming out of the spray arms. if it is and at a good rate, then the problem may be the spray arm jets blocked. the spray arms are only rotated by water coming out of the angled jets at their end or is the main circulating pump running ok?
SOURCE: How to remove upper spray arm of Maytag DWU 9200 BBE dishwasher
There is a plastic clip that holds the spray arm to the inlet line. This clip is in the center and has to be sqeazed together to release the arm.
Both upper and lower spray arms become clogged by different objects like paper, plastic, stems from fruits, etc... These are particles that cannot br dissolved be the detergents.
SOURCE: Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
SOURCE: Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
SOURCE: dishwasher not washing dishes properly
Thanks akubra_lands, it worked for me too on model DW28W. I thought I should elaborate on your answer for anyone else who comes across this while researching the same problem.
The repair is ridiculously simple (takes about 10min) and the only tools needed are 1 philips/posidrive screwdriver and 1 flat blade screwdriver. Assuming you've unplugged it from mains power:
Now take a moment to admire the handiwork of the engineer who planned the failure of that innocent little plastic flap around 6 months after the expiry of the warranty.
I actually had a repair man come and look at the problem, and yep, right on cue, he told me it needed a new pump motor. $300. When he realised I was on to him he just gave up. So hard for repair people to do an honest day's work these days..
Hi
If you
are noticing that the dishes are not clean, then there are a few things to
check for. Check the soap powder if it's kept in a dry environment. Also try
replacing the powder with something like a gel or liquid. Next thing to check
for is the water pressure and fill valve. Check if the water is filling in and
the spray arms are throwing the water with enough pressure. Try and listen to
the sound if you hear a proper spraying action sound.
If it
seems as a low water pressure then check the fill valve. Now, check if
dishwasher is draining the water or not. While the dishwasher is working check
whether the dishwasher is draining and there is not much left out water after
the cycle is complete. Try cleaning the spray arm with a soft brush. The water
temperature plays a major role in cleaning of dishes. The temp should be
between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
Dishwasher
Residue and Film on Dishes
heatman101
