Its getting gas to the carb but not to the plug
I would say it's a carburetor issue.. Open the screws on the bottom of the bowls. See if gas has a continuous flow...If no gas comes out then your float valves are sticking not allowing gas to flow..If the bike hasnt been rode for a while this might be your problem. You will have to take the carburetor apart to get to the sticking parts.
Testimonial: "the carburetor has been cleaned and gas is getting into the bowl but no gas getting to the pplug"
SOURCE: I have a honda mtd pro 11a-588q795 push mower and
Hello:
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>Pour a Small Amount of Gas (approximately 1oz) into the Carburetor Throat and Try to Start the Engine.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
If the Carburetor is the Cause, then
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
>>You can View a Breakdown/IPL of the Mower/Engine at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog American Honda.
>>You can View a Breakdown/IPL of this Unit at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM (MTD) and Enter the Model Numbers (). Then Double Click on the Model in the Results Area. Now you can Select the Section of the Unit you Wish to View.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
SOURCE: i have 1974 yamaha dt 250 enduro the bike sat
clean contacts on points with sandpaper (800 grit). located behind flywheel, will gurantee a fix. you can remove the side cover and get to contacts through holes in flywheel without removing it.
SOURCE: I have a 1984 honda xr 350 and i've changed the
Those bikes can be a pain to start after they've sat awhile. What always worked for me was twist the throttle a bunch. I mean make sure its flooded. Then lay the bike over on its left side until the gas runs out the overflow. Stand it up and lay it down until it stops running out. Then I squeeze the decompression lever and cycle the motor. Now just barely pull on the decompression lever to open the valve just barely. Get it to top dead center and give her a good kick with a twist of the throttle. Becareful it could kick back.
This technique works for when the bike stalls when its hot. Most important part is if you think its flooded lay it over and start the process over. Remember your XR has two carbs and will flood QUICK. After some practice you'll be able to hear it in the exhaust pipe if she's flooded or if she trying to come around. Trust me. I have four of these bikes. Two 83's, one 84 and my beloved 85.
SOURCE: Briggs and Stratton 6.5 hp won't start- not sure
Took carb. off and cleaned and put new kit in. Carb. is self choking. Put new primer bulb in. Will run with starting fluid then stop. Not getting any gas. Could carb. be clogged. I soaked it in carb. cleaner and blew out. Any suggestions would be greatly appreciated.
SOURCE: my 8n ford wont start with new carb, points,
I have also changed my plugs, points, cleaned carb, but I can not get the tractor to fire at the cylinders. I have spark but will not crank. What do I need to do?
