Connecting rod
Part Number: 315419-3
or
Woodruff Key 4
Part Number: 254001-2
Makita HM1211B Parts List and Diagram eReplacementParts com
Or broken spindle/ worn bearing(s)
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
SOURCE: what type of oil i will luricate to my makita HM
demolition hammers require hydraulic oil in most cases.
Any good tool shop should have hydraulic oil to suit.
SOURCE: what kind of oil does
Makita recommends using their brand of Makita Hammer Grease if you are doing the lubrication yourself.
You did not indicate a model number but all of their hammers have simliar instructions, 2 oz of grease, do not overfill which can cause faulty hammering or tool failure.
SOURCE: dewalt demolition hammer stopped hammering.
could be a few problems, the striker could be stuck from debris or the ram might be hydraulically locked. they make a rebuild kit for this tool if you are mechanically inclined. I would suggest first going to their site and downloading a parts breakdown and there you will find what is involved and the parts listing. It is "dewaltservicenet.com" and on the left hand side type in your model number and then follow the links to download this. Let me know if you need more assistance.
