Garden Logo
J
J Foster Posted on May 21, 2018
Karcher pressure washer runs constantly when turned on and blows washer hose off, when handle depressed on lance. Is this a spill valve problem?
5 Related Answers
Anonymous
  • 10865 Answers
  • Posted on May 31, 2009
SOURCE: Karcher Pressure washer surging/pulsing
here is a troubleshooting link for Karcher products
http://www.the-power-washer-advisor.com/electric-pressure-washer-troubleshooting.html
Håkan Sterner
  • 74 Answers
  • Posted on Jun 03, 2009
SOURCE: Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Anonymous
  • Posted on Oct 03, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Anonymous
  • Posted on Mar 26, 2010
SOURCE: I have karcher 620m pressure
Try this. While pushing the trigger of the gun, turn lance fully anticlockwise and then turn back fully clockwise.
Anonymous
  • Posted on Jun 20, 2013
SOURCE: Karcher dirtblaster does not oscerlate the water.
Stripped down the head of the dirt blaster by unscrewing the shaft from the end nozzle(it was quite tight). Removed the white disc from the nozzle using pliers and then cleaned out the 4 holes in the disc. Under the disc is an assembly which houses a ball bearing. I noticed that the ball bearing did not protude beyond the recess which houses it. I PUT TWO SMALL FIBRE WASHERS IN THE RECESS THEN REPLACED THE BALL BEARING. THEN REPLACED THE WHITE DICSC. Noting that the ball bearing protrude by approx 1/16th of an inch.
Re-assembled and the dirt blaster now works perfectly
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 • Garden
Karcher K2.94 intermittent pumping and buzzing
try the machine with the lance removed from the gun.
buzzing is usually the noise made by the motor when it cant turn. if the pump start to pruduce pressure but the pressure builds up too high then the motor will stop turning... faulty lance or faulty spill valve (dump valve)
Aug 05, 2013 • Garden
Have a Karcher kb4040 that continues to run constantly even when the trigger isnt pressed. Also water flows out of the detergant hose when im not pressing the trigger. Pressure seems down slighlty, not...
This is two things. One is the back flow check valve to the soap line is leaking. The other is the pressure switch on the output side of the pump.
Oct 13, 2012 • Garden
Washer doesn't reach enought output pressure. motor starts and stops at rendom.
First you have to do is try the machine without load. Attach everything as usual but do not attach the lance. Put on machine with water supply already on. If you close the gun the machine should stop. If you open the gun ( always with out lance)....the machine should start sending the water a bit far. If this is OK....then you have a lnance with a faulty, blocked NOZZEL.
NOrmally the machine stops when gun is released because there is a valve (Spill Valve) that actuates a electrical micro switch. This in turn closes off te elecreic supply...stopping the machine.
If with out lance your problem is still there....then the spill valve is faulty. AS I first said you must be sure that the nozzel is OK, so that you can blame the Spill Valve.
I raely service Spill Valves (Control Valves). I change with a new one. When open the cover using a TORX T15 screw driver....you locate the spill valve where there are 2 wires coming out. Some machines have the spill valve incorporated with the head and the intake and delivery valves unit. This I advize to change with new parts. These all in one heads are very good because at one go you change the spill valve and the other valves in one go.
Therefore in a few words you either have a blocked nozzel...or you have the spill valve faulty.
Also the delivery valves could be blocked...thus creating pressure inside and activating the spill valve to close off the electricity. You can also try to start the machine without gun and hose attached...but always with water being fed. NEVER put on a power washer without water being fed. And never store a power Washwer withpressure in it.
Fulltech.
Hope u can help when the karcher is conected up and the trigger on the handle is not depressed the machine makes a noise like its trying to presureise the hose it keep kicking in and out i have lost the...
The power washer stops when the gun is closed. This happens because pressure is exerted on a control valve (Spill Valve)...which in turn touches a micro switch and cuts electricity. Now most probably your machine is kickin in an out because the spill valve got faulty This happens when one stores away the machine with pressure still in it. NEVER store a power washer with pressure in it. The spill valve also gets faulty because left with soap and machine not rinsed. I rarely service spill valves...I change with a new one.
To locate the spill valve open cover (using a TORX T15screw driver)...and where you see 2 wires coming out...there is the spill valve.
Sometimes these machines have the spill valve incoporated with the head....in that case the whole head must be renewed. I also wish to tell you to try using the machine with out the lance. If all works good...then the on and off could also be comming from a faulty nozzel.
Regarding the Spill Valve...when it gets faulty...the machine also lose pressure. So in your case it is most likely that the spill valve is faulty.
Regards,
Fulltech.
1helpful
My 'k' pressurewasher keeps cutting out
Dear Sir,
The power washer stops when the gun is closed. This happens because pressure is exerted on a control valve (Spill Valve)...which in turn touches a micro switch and cuts electricity. Now most probably your machine is cutting out because the spill valve is getting faulty or stuck down and closing the micro switch. This happens when one stores away the machine with pressure still in it. NEVER store a power washer with pressure in it. The spill valve also gets gammed and faulty because left with soap and machine not rinsed. I rarely service spill valves...I change with a new one.
To locate the spill valve open cover (using a TORX T15screw driver)...and where you see 2 wires coming out...there is the spill valve. If you can manage to do this..you can try if you want to lubricate it by spraying SILICON spray. If you get it out..you use silicon grease.
Sometimes these machines have the spill valve incoporated with the head....in that case the whole head must be renewed. I wish to tell you to try using the machine without the lance. If it works correctly, then you have a faulty nozzel in the top of the lance. IMPORTANT...never run a power washer with water being fed!!!!
Regards,
Fulltech.
4helpful
2answers
I have a karcher K3.98 pressure washer. The unit surges when I put the wand on and then it stops working. I tried cleaning the wand (didn't make any difference) I then tried another wand from my son's unit...
Dear davedulmage,
To see if the unit is OK....first you must switch it on without water and without high pressure hose and gun. If machinr works smoothly, try by attaching a water supply. Now run the pump with water coming out of the outlet. If also in this case all runs smooth, then attach high pressre hose with gun but without lance. Put on the machine with gun open(to reduce initial resistance) and when you see a clear flow of water coming out...close the gun. The machine should stop. In this case I am suspecting that when you open again the gun the machine will not work. So it seems that when pressure is built in the pump a fault is occuring in the Spill Valve or also called Control Valve. When the gun is closed and pressure built up, this spill valve contracts and switches the pump off. When the gun is opened, the spill valve extends, putting the machine on and closing a valve at the base of the spill valve. So in your case it seems that the spill valve needs to be renewed. A spill valve gets stuck by incorrect using of the pump. For example leaving the pump with pressure in it for a long time. Also it gets stuck by detergents and chemicals. Sometimes I lubricate Spill Valves with high quality silicon grease....but it is much more practical to change it. When a new spill valve is put in....always run the pump with no load. This by usiing the gun without lance or wands, resulting in low pressure. If all OK...add a lance or wand that you are sure it is good. One final thing....to get to this spill valve you must put apart the body and expose the pump. If you are not that good at doing this job...it is better done by a more knowledgeable person. But changing the spill valve is worth it....because it is cheaper than a new machine.
Regards,
Fulltech.
2helpful
Karcher electric pressure washer
Dear mike husband,
One reasin for this fault could be a damaged lance or turbo lance. Try by replacing with new ones. If the problem is not solved, then the fault is due to a damaged spill valve. The spill valve could easily be damaged by using not suitable chemical or detergents. After using chemical detergents, one must always rinse the machine by passing pure water. The spill valve could also be damaged by leaving the machine for a long time with pressure in the system. One must never store such machines with pressure still inside. Always press the gun before storing.
Well the solution is to change the spill valve with a new one. In some cases even faulty suction valves can give this problem. But in the majority of cases it is the spill valve.
If you do not know how to fix this problem, it is better to be done by an expirienced technician.
Regards,
MG.
8helpful
2answers
Karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
4helpful
Karcher 520M Pressure washer won't operate at high pressure
I had the same problem - good water inlet pressure, no output pressure, even though the lance and handle seemed to be clear and working find.
I found that the electrical switch wasn't being operated correctly by the spill valve and wasn't turning the motor on/off correctly.
Inside the plastic electrical box there is a small white device that presses against the micro switch assembly. Carefully adjust the allen screw perhaps 1/4 turn out or 1/4 turn in to obtain correct operation of the microswitch - you will hear the micro switch clicking in and out when re-assembled. I'm sure they must have a rig to check correct positioning of this screw in the factory!
Hope it helps - mine is working find now and saved me buying another!
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
