I have a SEARS model 358.351191 (Poulan) 48CC Chainsaw. I had to clean the carb and reinstall it. Unfortunately it sat over the winter in a zip lock bag before reinstalling the Carb. Now I cant remember how to route the throttle cable so that it doesn't bind and will work correctly. Any help or pictures appreciated as the manual does not show the routing of the throttle cable inside the saw housing. Thanks Poe
SOURCE: Walbro wt hose routing on poulan saw
Carb has 2 nipples. top nipple gets line with filter on it from tank, bottom nipple receives line from bulb other side of bulb returns to tank
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
SOURCE: Primer bulb-carb routing
It should be like this.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
SOURCE: I need the routing of the gas lines on a poulan
how to route the gas tank lines in a poulan chain saw
