There has a lot of 2 person kayak in a market, But I think Intex Explorer K2 kayak is the best by design, prize. the maximum capacity weight of this kayak is 350 pounds. to know more details about this kayak you can check this link, here you can know all the knowledge about k2.
Intex Explorer K2 Admission Ticket to the World of Water Tourism
SOURCE: Towing capacity
Directly from the Toyota Spec Book:
Maximum trailer weight: 1,500 lbs
Maximum tongue weight: 150 lbs
Hope this helps; and, thanks for choosing FixYa!
SOURCE: What is the maximum weight capacity for the
I don't have the manufacturers specifications, but stay under 4 pounds and you should be ok. more that 4 pounds and you may have problems with vibrations. More than 10pounds and you may break the head, or tip over the tripod.
SOURCE: what is the maximum weight capacity for the Honda
look on the vin sticker(most likley on the steeting head on the frame) it will say GVWR, this is the max carry capacity. also the owners manual will give specifics as to the distibution of that weight.
SOURCE: maximum memory capacity in Kodak EasyShare C140
The C140 works with SD and SDHC cards, up to 32GB in size. By swapping memory cards, you have essentially unlimited memory capacity.
You may use any brand SD/SDHC cards, though personally I would stick with the major brands.
