SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
SOURCE: Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
SOURCE: My miele g886 dishwasher intake/drain light keeps
the inlet/drain light is a standard fault light and can mean anything without connecting the Miele dianostic software to the unit. This is only available to Miele service techs or service agents. If the light comes on in the first minute then it is probably a drain fault. Try checking the drain spigot at the sink end where the drain hose connects as these are usually the cause of most dishwasher faults.Hope this helps
