Question about Power Acoustik Car Audio & Video
Power acoustik radio model Pd-531 nb touch screen doesn't work . how can I fix it.
SOURCE:
zzedly
  • 300 Answers
SOURCE: POWER ACOUSTIK - A1800DB how to fix protection mode
If I don't ask the stupid questions first, I always get burned! Have you tried removing both the +12V and remote connections from the amp and letting it sit for a few minutes? If the amp doesn't automatically reset (and you have removed the condition that caused it in the first place), your amp may need repair, as it might have shorted something internally.
Posted on Mar 12, 2008
D3m0n1k
SOURCE: my power acoustik 8960 touch screen does not
return it...it will start jamming when loading a disc and the fan will start to grind soon.  it is a bad unit..like all 3 I have HAD!!!!!
Posted on Nov 28, 2009
TechAll
  • 99 Answers
SOURCE: I dropped my model No. A1241 phone and the touch
not having a crack on the screen doesnt mean your touchscreen will work. you said you drop your phone, it has a great possibility that it cause an internal damage to some of the microchip inside your phone that controls the sensors of your touchscreen.need to reheat the microchip inside it. open your phone and try to check for the microchip near the flex from the board of your phone going to your screen. then reheat it, but dont move it.
Posted on Jul 10, 2011
Daveatwhips
  • 492 Answers
SOURCE: I have a power acoustik
You shorted the LED display. The touch screen is not effected by this. If you don't have a shop locally that works on headunits, then you will need to purchase a new one. Always make sure to unhook the battery before doing an install.
Posted on Jul 31, 2011
  • 3247 Answers
SOURCE: Why calibration want go off my screen of my radio
Your model must be PD-931NB.
If you do not have the manual you can download this from this site.
http://www.poweracoustik.com/pa2012/manuals/PD-931NB.pdf
I am assuming you are following the calibration procedure on page 40 of the manual. (refer page number printed at bottom of pages).
As this is to do with touch screen calibration, the most likely cause of the message coming up is a dirty screen. If cleaning display is not helping then the touch screen circuit is faulty.
Posted on Sep 01, 2014
I have a power acoustik pd 624hb and the background color that needs to be black is white how do I fix this problem
This is indicative of a failed/failing lcd screen. If under warranty return to manufacturer. If not probably cheaper to replace.
Jul 04, 2016 | Office Equipment & Supplies
I need to reset my touchscreen car radio everything froze and the screen just stopped working
I was unable to retrieve the manual for your unit. I would unplug your car battery for an hour or so. I would then reattach the battery cables. This will hopefully reset your stereo. Now try to use your car stereo as you normally would. If this works you will have to set up the stereo again.
May 28, 2015 | Power Acoustik POWER ACOUSTIC PD-931NBT...
How do i stop a power acoustik pd-450 from randomly shutting off? Ive checked connections and wiring all is good, the power supply is good as well
how random is it? Make sure the radio is grounded properly. Look in the pin outs in the harness and make sure there is a ground there. Also, you may have 1, 2, 3, or 4 bad speakers. A short in any one speaker will send the radio in protect mode. Also, If your radio is seeing less than something around a 3ohm load (technically 4) it will protect itself as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Dec 26, 2014 | Power Acoustik Car Audio & Video
I made a mistake and hit the sync button on my radio..and now theres a white screen with across in the corner and i cant utilize the screen or cds or dvds..only the bluetooth works...ive removed the car...
You probably have on your car stereo either a single push button that you press to select the audio source (Radio/CD/DVD/Bluetooth) or 4 separate buttons labeled: Radio, DVD, CD, Bluetooth, respectively. Because a sync operation can refer only to a Bluetooth audio source (phone, tablet), your stereo is in now in the source mode for a Bluetooth audio source. Find the button or buttons for the selecting the audio source and select Radio or CD or DVD (you are already on Bluetooth).
Dec 05, 2014 | Power Acoustik Pd-740nb Car Stereos with...
Why calibration want go off my screen of my radio power acoustik model 931nb
Sep 01, 2014 | Car Audio & Video
Power acoustik pd 702
turn your can on ACC that turns the radio on but nothing else. you can always put the radio on a switch power and not on the cars IGN power
Nov 26, 2013 | Car Audio & Video
How do i bypass the brake wire on the power acoustik ptid8940nr
Take the brake wire an connect it 2 your Orange wire(dash light dimmer) it is a constant 12 v power when radio is on
Feb 18, 2010 | Car Audio & Video
Car Audio & Video Logo
148 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
