Then the elements stopped working. little while longer the light with the combo clock, oven temp and timer went off. If I turn the elements on, the little indicator lights that say its hot comes on and the clock starts flashing 12:00. I can then set the clock and turn the oven on (but still doesn't get hot). when I turn the element to off, the clock and everything goes back off. ive checked the constant 220 already.
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
SOURCE: Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
SOURCE: stove is not getting hot or elements
sounds like you've lost one phase of your 240 volt power
SOURCE: Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
