Ron watkins,
If the tank fill there is surely air inside the tank and gauge must show as normal, if there is air inside the tank it will deliver with the outer plug. so here no pressure is developing inside the tank,,,,Check the both inlet and exit reed valve, either one is faulty....replace with new,
this will work..
with regards,
jaijith
SOURCE: Air pressure gauge does not move on Craftsman 1Hp, 12 Gal. Air Co
I would say that the gauge needs to be replaced. These are common items so go to any auto parts or craftsman hardware store and purchase a replacement.
be sure to use some joint compound or teflon tape on the threads so u dont have any leaks.
please rate my answer. thanks.
SOURCE: 2004 Porche boxter - Filled petrol tank & guage still empty
It sounds like problem with either gage or sender unit in fuel tank.
What warning massage from computer.
SOURCE: 2002 honda crv fuel gauge moves really slow.
I had the same problem. My battery was going bad. When I replaced it with a new one, the fuel gauge worked fine.
SOURCE: no air pressure at the hose
It sounds like you have trouble with your pressure regulator. Make sure that the knob for the regulator is turned clockwise to increase pressure. If this doesn't work, you may need to replace the regulator.
SOURCE: gas gauge shows empty after filling gas tank
The gauge circuit is shunted on most cars, this is wierd, but needed to stabilize the readings... Your description sounds like normal function. Drivers would complain if the qauge were to be instant, going around corners, starting, stopping, all move fuel, and the gauge would indicate this, cauing driver alarm...Been this way for ever, although yours sounds like it is on the far side of the scale...if it reads correctly after a while, you could replace everything and you would have the same performance.
