SOURCE: I have a washing machine ASW-A95HT but suddenly it
The standard things to check on all washing machines:
1. check the inlet pipes..if the machine has 2 inlets (hot & cold), both should be connected to pipes.. in your situation, its doubtful that the pipes are not connected, but perhaps it got detached through vibration.
2. ensure that the machine is level, some machines have an auto shutoff safety mechanism which prevents it from working if the machine is not exactly (horizontally) level.
3. If you have just used it for a load prior, perhaps it has overheated.. in this instance, just leave it alone for 20 minutes and it should sort itself out.
SOURCE: my washing machine wont spin
Sounds like the belt broke on your washer.
Easy to replace and not that expensive.
