SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
SOURCE: Setting the time on my clock on radio Model # RP3755B
Well, I have an RCA clock radio/CD player and just figured it out. Press the "Time" button and hold it down while pressing the CD "Forward" button. Hope it works for you! Ron
SOURCE: HOw do you set the clock on an RCA RP9328A stereo without remote?
I have this system. According to the manual you have to do the following. 1. Press and hold the TIMER/CLOCK button until CLOCK appears in the display under the time. 2. Press the SET button once and the hour will flash. 3. Use the << or >> buttons to ascend or descend to the correct hour. 4. Press the SET button again and the minutes will flash. 5. Use the << or >> buttons to ascend or descend tot he correct minutes. The time will flash for a few seconds and be set when it stops. I have tried those steps and you may have to do them a few times in order to get the time right. It's a little tricky. I haven't bothered to reset the time as I have other devices that display the time without the back and forth with this device. It's a nice system and the sound is okay for my purposes. Hope this helps.
