Health & Beauty Logo
c
chuck bailey Posted on May 18, 2018
Can phillips norelco shaver be used in europe with adapter plug ??
4 Related Answers
Anonymous
  • 10865 Answers
  • Posted on Mar 25, 2010
SOURCE: Using Norelco 3801XL shaver in Europe
hello. In order to use these devices in Europe you need a power adapter. Go to this link to learn all about it
http://goeurope.about.com/od/electricityineurope/tp/power_adapters.htm
Joe. Please rate my answer as very helpful. thank you
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Aug 21, 2010
SOURCE: disasembly of a phillips norelco
Remove the 2 screws on the back and remove the back cover. This will allow you to access the inner cover that has 3 screws. Remove those screws and take off the inner back cover to access the battery. Be sure to read the NOTE concerning installation on that page
You will find the battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Sep 29, 2010
SOURCE: I am in Europe and
Model 5861 has worldwide voltage capability and can be charged from 100-240V without requiring a voltage converter. If your shaver cord has an American plug, you will need a simple adapter to fit European wall outlets. You will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/international-plug-adapter-for-use-in-continental-europe-p-408.html
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Apr 06, 2011
SOURCE: phone # for Phillips Corp,
You can contact Philips by phone at 1-800-243-3050
How do I register my Philips Electric Shaver off line
Create a phillips account
Login PHillips Log in
Login Phillips sign up Look at bottom of page and Log in with account.
2helpful
I have a Norelo 985RX and I would like to know if it is possible to use it in Europe (220V 50Hz) with just a simple plug adapter (not a converter)
Yes, model 985RX has an internal automatic worldwide voltage circuit. You will only need a simple adapter to fit the wall outlet of the country you are visiting
1helpful
I am in Europe and need to recharge my Norelco shaver 5861. Will it damage the batteries if I use an adaptor and plug the shaver into a 220v outlet?
2answers
1helpful
Can the Norelco 3805 XL be charged from a European 220 VAC supply? I purchased it in the United States and am about to take a trip to Europe.
model 3805XL is compatible with 100-240V. You will not need a voltage converter but you will need a simple adapter to fit the european wall outlets. These can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/catalogsearch/advanced/result/?manufacturer[]=39
1helpful
2helpful
2answers
Lost head for PHILLIPS HS8460 shaver
philips norelco HS85 replacement heads for electric shaver norelco hs8460 blades replacement parts.
3helpful
Electrical specs for Norelco 5810 XL shaver
Yes. It has the universal power supply. You will need the country adapter, but it will run on 240v. So says the support center at Phillips.
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
