Sewing Machines Logo
J
Jennie Anchor Posted on May 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot lower the presser foot on my necchi 681c sewing machine
R.A. Ellis
Level 3:
  • Necchi Master 12,731 Answers
  • Posted on Jul 16, 2018
R.A. Ellis
Necchi Master
Level 3:
Answers
12731
Questions
Helped
2613596
Points
59176
In addition to oil, directing hot air from a handheld hairdryer at the mechanism may loosen it quicker.
NOTE--if your machine is computerized, do NOT apply oil to your machine as it could cause permanent damage!
BJ Cook
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 15, 2018
BJ Cook
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
830
Points
Open the light cover
put some sewing machine oil on the long round
thingee, just above the black square
let this set for awhile
then use a chop stick or pencil/pen and push down [gently!!] on the square while pushing the lifter down
if this doesn't help, put a drop or 2 more of oil and let it set awhile longer
or use WD-40 to break it loose and then clean the long round thingee and put sewing machine oil on it
5 Related Answers
Anonymous
  • Posted on Apr 11, 2008
SOURCE: Old sewing console with new machine
I have a very old Necchi machine and I need a new belt for it.
radcal
  • 196 Answers
  • Posted on Jun 12, 2008
SOURCE: Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
Anonymous
  • 27 Answers
  • Posted on Jan 14, 2009
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Anonymous
  • 37 Answers
  • Posted on Apr 16, 2009
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
ken dourof
  • 980 Answers
  • Posted on Nov 04, 2009
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
How do you raise the pressure foot on the Necchi 3204fb sewing machine?
the presser foot lever is either on the left side of the machine where face plate is or at the back of the of the machine on the left
There are loops of thread under the bobbing when i sew
Lift the presser foot and pull about 8" of thread through the needle.
When threading a sewing machine, make sure the presser foot is up as this opens the tension control so the thread can be properly seated and controlled once the presser foot is down.
How do I set the tension on my Necchi 3101? I want to freehand motion quilt on it.
The tension is not changed.
You lower the feed dogs, or change the stitch length to zero and cover the feed dogs by taping an index card (make a hole for the needle) over them.
Be sure to use a darning or free motion foot and have the presser foot down when stitching.
What is the adjustable dial on the left of the machine inside the door and above the needle shaft ...it seems to make the pressure on the presser foot increase...when would you use it?
Hi. That little dial does control the pressure on the presser foot. Generally, you lower the pressure for lighter weight fabrics and increase it for heavier weight fabrics.
Happy Sewing!
Robbie
Attaching fit button-hole foot?
Just pull down on the original metal foot. It will snap off and then you can snap on the button hole foot. Good luck!
Trudy
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
