Question about Kenmore Washing Machines
Have a kenmore oasis elite top load washer. I getting error f2. This is a communications error. I originally had error f32. changed Washer Control Board Part W10189967. Went from f32 to error f2.
Put original board back in back to error f32. Talked to vendor and they replaced the W10189967 board. Upon install error f2 again. I find it very hard ti believe both boards are bad. I also changed the W10131867. Same result.
    Sergeant:
  • Kenmore Expert
  • 227 Answers
Check the water pressure switch an switch hose
Posted on May 25, 2018
6ya staff
SOURCE:
Rotu
Douglas Henry
  • 175 Answers
SOURCE: Thermador Built-in Oven Model SMW272
usually this is because you have the connecter on the touch pad off by a pin or not seated well. sometimes all it takes is taking the front touch panel off, re seating the connectors, and putting it back together. these thermadores are very sensitive to it for some reason. if all else fails, take all of the small multi pin wire connectors off one by one and re seat them. it should take care of the problem if it wasnt there before you started. good luck!
Posted on May 15, 2008
abhishek33
ABHISHEK.C
  • 1239 Answers
SOURCE: amana gas stove acf3325ac f2 code
HI The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
PLEASE RATE IT............................
Posted on Nov 16, 2008
Mike
  • 57 Answers
SOURCE: kenmore oven doesnt bake
Can I assume that you determined that the bottom burner flame is burning properly? To do this, remove the oven bottom insert. The flames should have approximately 1" of blue cone and should burn with no yellowing tip, if on natural gas. (A small yellow tip on the end of the outer cone is normal with most LP gas.) The flmaes should not lift off the burner ports. If the flame is lifting, gradually reduce the air shutter until the flame stabilizes.
Go to the following website for your particular manual.
http://www.hammerwall.com/Manuals/Kenmore/Description/362.75585890/Kenmore%20Free%20Standing%20Gas%20Range%20Owners%20Manual/L0522834/
Posted on Feb 16, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Our Whirlpool oven started beeping
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#@!
Posted on Oct 01, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: My whirlpool wall oven displays E1 F2
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^^^^^
WHAT IS THE REASON OR CAUSE POSSIBLE FOR WHICH IS IN CODE F32
I did a "GOOGLE SEARCH" on 'KONICA MINOLTA 1312 ERROR CODE F32" and this was the results. Hope this helps!
F32-01, -02, -03, -04, -05, -06, 07Fan motor problem, AC board or ADU stand drive board
Apr 21, 2013 | Konica Minolta 1312 Black Toner Cartridge
Tip
Repairing an (F2 E0 or F2 E1 error code) Failed Whirlpool Builtin Oven Keypad...
A replacement touchpad is now available from Ledgestone Technologies to replace various membrane keypad switches that are not available from the OEM.
These are in stock and can be shipped today from fixyourboard.
Find the full list of applicable models here:
Introducing the Ledgestone Technologies Touchpad
Step 1. Remove Original Plastic Bezel
BE SURE TO REMOVE POWER TO OVEN FIRST!
You are going to re-use the original plastic bezel. Remove the panel from your oven that contains the keypad and control board. Uplug the keypad from the control board. Remove the control board from the panel (4 screws).
Step 2. Remove Original Touchpad Membrane
With a heat gun, lightly heat the original keypad from the back of the panel. This will soften the adhesive. Gently but firmly push the old keypad off the bezel by pushing from the back of the panel on the keypad window. Carefully remove the original keypad membrane element. Most of the original adhesive should pull off with the keypad. Rub off any remaining adhesive.
Step 3. Install New Ledgestone Touchpad
Remove adhesive backing paper from the Ledgestone Technologies KP1308A1 Replacement Touchpad Membrane. Align and adhere new touchpad to recess in plastic bezel. Below are examples of black on black and gray on white. Gray also looks good on bisque or almond.
Step 4. Re-install Bezel on Oven
Re-attach control board to bezel, plug-in new keypad. Re-attach bezel to oven frame. Done!
Applicable Models
RBD276PDB10 RBD276PDB11 RBD276PDB12 RBD276PDB7 RBD276PDB8 RBD276PDB9 RBD276PDQ10 RBD276PDQ11 RBD276PDQ12 RBD276PDQ7 RBD276PDQ8 RBD276PDQ9 RBD306PDB10 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDB14 RBD306PDB15 RBD306PDB7 RBD306PDB8 RBD306PDB9 RBD306PDQ10 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDQ14 RBD306PDQ15 RBD306PDQ7 RBD306PDQ8 RBD306PDQ9 RBD306PDT11 RBD306PDT12 RBD306PDT13 RBD306PDT14 RBD306PDT15 RBD306PDZ10 RBD306PDZ7 RBD306PDZ8 RBD306PDZ9
Original Whirlpool Touchpad Part Numbers
4451969 4451970 4451975 4451976 4451977 8300431 8300432 8300437 8300438 8300439 8300640
on Aug 17, 2015 | Ovens
Kenmore oasis HE Top load Washer stopped in the middle of a cycle. No power and will not unlock
error code? totally unresponsive? try reseting power then if unresp. replace main control. verify 120v into board. 3 screws on rear of console and lift.
Sep 16, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Displaying E6 & F2 code
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Check additional details in THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 13, 2011 | Ovens
I get F2:E0 F2:E1 and F2:E3 as well as the continuous beeping. Unplugging does not resolve the problem. I can turn on the oven, sometimes, but it goes off by itself. Sometime the controls don't work at...
Kitchen Aid Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line openfrom what this says you could have a bad touch pad,it says to press cancel,if the code comes back after a minute you have a bad touch pad.there's a tech sheet on you machine with all the codes on it,look behind the top console taped to the back.make sure you put this back,if someone comes in to work on your machine and that paper is gone it will be hard to work on it,all machines are different.
Apr 21, 2011 | KitchenAid KGST307 Gas Kitchen Range
I keerp getting F2 error on my kenmore elite top load washer? is there a solution?
The F02 error code indicates keypad/user interface failure. Most of the time, this is caused by a problem in the keypad/user interface. It can sometimes be caused by a failed control board.
You could have an intermittent problem such as a stuck key or contact. As long as the F02 is not displayed, the washer should work normally. You can continue to use it when the F02 is not displayed. It is still safe to use the washer.
Sometimes this problem is caused by a loose wiring harness connection between the keypad/user interface control board and the machine control board.
Nov 26, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Windows Live Sign-in Assistant is not working. When I click on it, I get a message prompt that windows live messenger stopped working and I get this following after.. .....C:\Program Files\Windows...
Try installing the program again using the original installation media or contact your system administrator or software vendor for support.
Jul 09, 2017 | Computers & Internet
Kenmore Elite Oasis HE Model #110.27087604. My washer had an error code "ld". I removed the hoses from the pump and discovered loose change in the pump that was probably jamming the impeller. I removed...
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Jul 14, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My microsoft office 2007 suddenly crashed. then after i restarted my laptop, whenever i open a microsoft office file, it would say that the OS (windows vista ultimate) is not designed to run on Windows or...
you should completely un install the office suite before installing it again. If you can, I would greatly suggest, using the last good restore point before the main crash, this will put the registry back to original too.
Jun 25, 2010 | Microsoft Office Computers & Internet
Washing Machines Logo
89 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
