SOURCE: Will not add toner
Reinsert cartridge and restart it by unplugging or powering off
It should refresh the memory
Good Luck
SOURCE: Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
SOURCE: Toner Problem
Check for obstuction of the toner level sensor, (ie: dust, dirt, toner spillage). Be sure to go into control panel settings to tell the unit a new cart has been installed if there is no auto-sensor. Check the eletrical contacts inside cavity and contact points on cartridge for oxidation.
