Refrigerators Logo
Larry Wall Posted on May 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Goldstar A/C model #GP120CE that quit cooling. I think the compressor is not working. Is it worth fixing?.
AJMAL KHAN
Level 2:
  • Expert 388 Answers
  • Posted on May 17, 2018
AJMAL KHAN
Expert
Level 2:
Answers
388
Questions
0
Helped
110024
Points
869
Check Thermostat setting, if its ok then make sure for compressor working or not.
Or try to change thermostat only if u r unable to get the result.
Compressor having long life its rarely being NG.
Hope your answer is completed.
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jul 24, 2009
SOURCE: model dss25pfmdww quit cooling
We do need to check the PC board part number WR55X10656
Anonymous
  • Posted on Jul 29, 2009
SOURCE: i have a Goldstar model-GP120CE and it has stoped
There is two drain plugs on the back of the unit, you will need to drain the the bottom black plug, you need something to catch the water. hope this helps
Anonymous
  • 1606 Answers
  • Posted on Sep 06, 2009
SOURCE: Fridge working but not cooling.
The white component you see , is the problem . That is the overload/relay . These short due to power surges , dirty coils in the front bottom of refrig , or just by age . They short , to save the compressor , when one of these happens . The part number you need is # 8201786 . This part just prys off (maybe one wire clip ) , easily replaceable with instructions included with the part .
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jan 10, 2010
SOURCE: Magic Chef Compact Mini Fridge Model
Might just be the compressor relay. They had a bunch of them go bad in recent years. I have repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • Posted on Jul 19, 2010
SOURCE: I have a Goldstar GP120CE Portable with an error
If you have a goldstar GP120CE portable air conditioner with the E3 error and it's not under warranty you may be out of luck.When I called LG, (who owns Goldstar), they said these units are not cost effective to repair so finding a company to service them is difficult. If it were under warranty they would exchange it..
Goldstar GP120CE portable air conditioner with the E3 error
Sounds like a clogged condenser pipe which is common for portable Ac . It is usually due to the unit sitting low and collect more pollens an particles at floor level. A pipe cleaner tends to do the trick. Also insects tend to harvest inside the drain pipe
I've had my air conditioner for a few years now and it no longer cools anything. The fan works, the condenser(?) turns on when I set it to cool instead of fan, but the air coming out of it isn't...
You need to determine if the compressor is running, if it is and you have no cooling then you either have lost charge or bad compressor, these units re not worth replacement compressor
We have a Goldstar portable AC. It runs fine but
Refrigerant leak.....not worth fixing.. will cost more then a new one...
Here is a tip for other things you can check first....
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
5,200 BTU unit. Compressor and fan both work when first turned on, then compressor quits after 5-10 minutes of operation. Won't turn on again even after 5-minute fan-on cool down. Process repeats after AC...
this could be just a simple fix of cleaning the condenser coils. If semi-clogged, it can cause higher than normal pressures and cause the compressor to cut out on it protector. Check it out.
Air conditioner not cooling
Most likely cause is you have lost your coolant/ freon
These low end unit are generally not worth recharging you can buy a new one for less than a tech will charge you to fix it
I have a 10+ year old Kenmore side by side that quit cooling
the starter unit of the compressor can be bad EZ fix if it is that...its the element conected to the compressor :)
Amana refridgirator not cooling
check thermo stat or defrost timer and all elec. connections
5helpful
I have a Goldstar model-GP120CE and it has stoped working and P2 appears on the display. I know the collection tank is full and im supposed to drain it but what and where is the collection tank??
1helpful
I have a Goldstar GP120CE Portable with an error code E3. What do I do to fix it.
Top Goldstar Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
David Spradling
David Spradling
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
