Try downloading and installing visual c library files
see
https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads
SOURCE: Family Tree Maker Deluxe Edition,
you need to open my computer -> then on the top toolbar click on tools -> and folder options
remove the x from simple file shareing, if visible.
Then go to c: drive then folder ftw and find file ftwbmp.dll right click and select properties
you need to remove the X from the read only.
SOURCE: Broaderbund Version 6 Family Tree Maker
Hi madelyn evan,
Version 6 Family Tree Maker is designed to be used with Windows 95 / 98 , therefore in order to use it in Vista you must run your program using Compatinity Mode --> Install your software--> Go to your Desktop --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
I hope this helps. If so, please take a moment to accept and rate my solution accordingly
SOURCE: I have the Installation programme
Yes, it should run on Windows7, as I have done it some time ago. I have experienced a problem with the some printing options to PDF format, and I need to find a amyuni document converter to overcome this problem. Everythings else works and will not cause any problems to your existing files you have compiled
SOURCE: Is my Family Tree Maker
It is not with Home Premium. You need to upgrade to Windows 7 Professional
