Measuring Tools & Sensors Logo
J
James Kovacs Posted on May 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil&filter change on Briggs&stratton IC quiet OHV14.5 hp engine.What kind and how much oil? What type of filter?
Marvin
Level 3:
Top Expert:
  • HP Master 85,242 Answers
  • Posted on May 15, 2018
Marvin
HP Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29057464
Points
266281
Oil Recommendation
  • SAE 30 40° F and higher (5° C and higher) is good for all purpose use above 40° F, use below 40° F will cause hard starting.
  • 10W-30 0 to 100° F (-18 to 38° C) is better for varying temperature conditions. This grade of oil improves cold weather starting, but may increase oil consumption at 80° F(27° C) or higher.
  • Synthetic 5W-30 -20 to 120° F (-30 to 40° C) provides the best protection at all temperatures as well as improved starting with less oil consumption.
  • 5W-30 40° F and below (5° C and below) is recommended for winter use, and works best in cold conditions.
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Apr 19, 2009
SOURCE: briggs & stratton 3 hp engine will not start
likely needs a carb kit
Anonymous
  • 10865 Answers
  • Posted on May 19, 2009
SOURCE: White Smoke comming out of Briggs and Stratton 21 HP V2 engine.
The white smoke may have been caused by having water in the fuel, or fuel tank [due to condensation or exposure to rain and snow]. It may have been that the mower got tipped for cleaning purposes, blade inspection, etc. and oil from the low lying oil pan got into the piston.
Either way, I recommend installing a brand new spark plug and new gasoline [you can purchase a little gas siphoning hose for a dollar or so at any auto parts store] If you have gasoline left over in a can from last year it is safe to use it in your car as it mixes with lots of new gas, but not in your small mower tank as it is basically outdated fuel.
Dwain Pippen
  • 377 Answers
  • Posted on Jun 12, 2009
SOURCE: Fuel in tank going into engine and mixing with oil
The float needle and seat are leaking and not shutting off the fuel when carb bowl if full. It then flows down the intake into the cylinder, past the rings and into the crankcase. Have the needle and pressed-in brass seat replaced. Could save yourself some money if you removed the carb yourself and took it in.
Anonymous
  • 41 Answers
  • Posted on Aug 04, 2009
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Anonymous
  • 1305 Answers
  • Posted on Aug 29, 2009
SOURCE: what type of oil for a 650 series briggs and
B/S webpages show that they recommend a Synthetic 5w-30 oil for their small motors...
K
HOW DO I GET A REPAIR MANUEL FOR A BRIGGS AND STRATTON 12 HP IC QUIET ENGINE
Try website for Briggs & Stratton. Or use Google Search for Briggs & Stratton 12 HP IC Quiet Engine Manual.
Briggs & Stratton 18 hp motor oil white
White oil in any motor indicates the oil has mixed with water . Drain the oil change the filter and find out how the water got in.
What kind/type engine oil for the 17.5 H.P. Troy-Built Pony garden tractor?
sae 30 weight is used for most garden tractor engines. This is straight 30 weight oil not a multigrade. Most big box stores that carry this kind of gear have it.
2helpful
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
6helpful
What kind of oil does the 22 hp briggs stratton take
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
2helpful
Top HP Measuring Tools & Sensors Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a HP Measuring Tool and Sensor Expert? Answer questions, earn points and help others
