SOURCE: How do you load staples
On the right side of the machine are two levers, the one towards the rear is a release button. It releases the "magazine" that holds the staples. Turn it and the magazine will slide out, then put your standard staples in and close. It took a little manipulation of the lever before it released on mine, and I expected the magazine to pop out as if spring loaded and it did not. Try gently pulling on the magazine whiole turining the lever, and it should work!
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy
Instructions
