Question about Lanier Office Equipment & Supplies
Lanier pro8100 finisher error code SC720-26.How do I reset the code by going in to service mode?How do I test finisher motors by going in to simulation? Thanks
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
Nov 21, 2014 | Lanier 5612 Fuser Spring For Picker Finger...
How to reset fuser error code on lanier ld235?
Come into test mode, if it comes back the fuser service needed. -Carl
Oct 06, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Describe your lanier sc 542 Problem Machine turns on and then gives this code.
This is a hot section problem, can be reset by entering service mode (pushing in sequence clear modes 1-0-7 hold stop button down for 5 seconds) but this is a bad code...service call? -Carl
Nov 13, 2010 | Lanier 1205 Copier
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
Sc 546 lanier ld
This is a fuser error code resetable by entering service mode. -Carl
Jun 10, 2010 | Lanier 1205 Copier
Lanier 5645 has a sc542 error code
this is a problem with the thermistors and will need a technician to come out and fix it for you, the part #'s are aw100052 and aw100053 for the thermistors but you have to enter service mode to clear and reset the code.
if this answers your query please rate my answer accordingly
Regards
Sep 14, 2009 | Lanier Office Equipment & Supplies
Lanier copier ld145 locked up, code is sc546
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Jul 29, 2009 | Lanier Office Equipment & Supplies
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
May 15, 2009 | Lanier Office Equipment & Supplies
283 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
