Contact Foodsaver to ask how to clean the drip tray.
http://www.foodsaver.com/service-and-support/service-and-support.html
At the web site shown above, an online chat person will appear and ask your name and information to help you.
Service Support FoodSaver
SOURCE: Cleaning drip tray.
I have just removed the drip tray from my fridge freezer and it was relatively easy.
Do not remove the compressor unit.
The drip tray is held in place by a metal clasp which is welded to the top of the compressor. The clasp is a flat piece of metal which must physically twisted to align with the key way in the plastic drip tray. I used thin pair of pliers to grip the clasp and twist it clockwise to line up with the tray key way. The tray then has to be carefully manouvred off the compressor so as not to cause damage or spill it foul smelling contents. This I managed to achieve fairly easily.
Clean out and install then twist the clasp to clamp the tray into position. I don't know what would happen if you didnt lock the tray back in position as it does not seem capable of falling off on its own and it would be easier to remove next time.
Hope this makes sense
Mark
It isn't a Coffee Maker, correct? It is a Foodsaver FSV12927/14931 ?
