Question about Garden
I need diagramfor deck belt on a Scott’s rear engine 10.5 model number c3011000 pretty sure 30” deck and belt size can’t find anything on this mower
  • Dan Clancy
    Dan Clancy Jun 20, 2019
    I have a complete parts & owners manual. For your Scott's turfmaster 30 inch deck rebel280@verizon.net
    Top Expert:
  • Garden Master
  • 52,781 Answers
Contact Scotts directly and request information for model c3011000.
Posted on May 14, 2018
SOURCE:
  • 24 Answers
SOURCE: murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
Posted on Feb 08, 2009
  • 10865 Answers
SOURCE: Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
bargainbin2
  • 123 Answers
SOURCE: replacing deck belt
Here ya go.
Posted on Aug 26, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
I need to get a drive blade belt for my ryobi model rt190 riding mower with 19 hp engine and 42 inch deck. Can you help me get the correct one?
According to what I can find ( maybe correct but check diagrams to be sure ) mower model should be HDK19H42. Drive belt shoul be item 57 on drawing part number 532140294 Mower deck belt item 68 part number 532144959.
Jun 12, 2018 | Ryobi Garden
I need a drive belt for a Scott riding lawn mower
not enough information provided check with a dealer close to where you live .take make /model/hp and deck size with you
Apr 11, 2015 | Garden
Model 13aj771g031 huskee lt4200 lawn tractor 18 1/2 HP engine. 2009 yr. Need to find out deck belt size. Got far enough to find out its part 44 on sears part diagram but that's as far as I got. No size or...
It is a "G" deck which is the 42" Cut.
Deck current part number 954-04060C which is 1/2" x 96-1/2"
Just Google 954-04060 and you find several online suppliers.
Pricing depends on the supplier and if it is OEM or aftermarket.
Mar 28, 2015 | Sears Garden
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I need to know the belt size and part number for the 915037 1844 ariens zeroturn
Hi and welcome to FixYa, I am Kelly.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
Make sure pop-ups are enabled... (No ads on site)
Enter this model number:
915037-000101
Then on the side of the page choose: (Scroll) Mower Deck, Belt Idlers and Blades
There are 5 belts listed! There is nothing that relates to a mower or deck serial number either.
You have to know the model numbr of the deck (see item 1 same link to cross ref your belt size)
035
Belt PN: 07241700 V belt (037) = 44 inch deck model 51519000 & 5159100
039
041 / 313
Belt PN: 07242900 V belt (501) = 44 inch Deck Model 51510400
Thanks for choosing FixYa.
Kelly
Sep 10, 2011 | Garden
My lt1000 craftsman riding mower belt broke. I bought a new one and can not seem to find the manual to see how to replace it. Can you show me a diagram please?
On your mower, lift up the seat and you will find a silver sticker with numbers on it. There is a 9 or 10 digit model number. It will look like 123.456789 Go to www.searspartsdirect.com and input your model number and perform a "model" search. I am assuming that the belt you are referring to is the deck belt. Go to the deck section and you will see a basic pattern of what shape the belt will have when installed. There are 2 kinds of pulleys on your deck...V-groove & flat side. The v-groove pulleys go on the inside of the belt, the flat side will go on the outside of the belt.
If the mower is more than 3 or 4 years, it is probably a good idea to replace the drive belt(s) also.
Good luck.
Oct 22, 2010 | Craftsman Replacement Belt for 42" Deck
Troybuilt riding mower won't pickup grass
can you tell me if unit has timmed blades and is the unit a rear catching unit ?
be sure engine speed is correct most applications this between 3400-3600 rpm
if unit has timmed blades - be sure that the blades are timmed correctly , and the correct blade is on correct side
if not timmed be sure blades are sharp and balanced , make sure the wing turn up is ok ( blade speed and turn up creates air velocity)
make mandrell vents are clear if unit has them , make deck belt is not slipping, and is not damaged
make sure deck belt tension is correct
make sure pulley splines are ok and are fixed tightly to spindle shafts and keys are in place
make sure the catcher vents or bag are clear and air can flow through,
lastly be sure that the deck is set level side to side and the deck has between 5 - 10 mm rake that is the height of front of the deck is 5- 10 mm lower than the rear of the deck
and the deck lifts up evenly
note let me know model and spec number of ride on mower
will try and help further if this info does not help
cheers paul46
Sep 13, 2010 | Troy Garden
How too replace the blade drive belt on a murray lawn mower
Its actually really easy. First, determine the size of your mower deck. Is it 30" 42" 54" etc. Then, go to a home improvement store like Lowes or The Home Depot (or an online retailer.) Search for a replacement belt for your deck size. Removing the old one is easy. Pry back the retainers on the engine pulley and slip the belt off of the pulley. This should make it very easy to pull off the mower deck. Installation is the opposite of removal. Make sure you note the belt arrangement for proper installation. Good luck!
Jul 09, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
42" craftsman mower deck belt 144200 to tight on the deck
Manual lists the incorrect number for this model! i learned through many difficulties. Correct belt is a # 144959, 1/2 " by 95"
Aug 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
119 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
