Garden Logo
J
Jake Posted on May 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Husqvarna neutral lever is not locking the tires.
My Husqvarna YTH2348 96040022 01 Will not start. The Neutral lever on the back does not seem to completely lock the wheels. I can still push the tractor although it is slightly harder to push than when I have the rear wheels unlocked. I can reach under the tractor and feel that the lever is pushed all the way forward.
Andrew White
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Husqvarna Master 365 Answers
  • Posted on May 15, 2018
 Andrew White
Husqvarna Master
Level 3:
Loyalty:
Answers
365
Questions
0
Helped
202797
Points
1022
Stating the obvious you should not be able to push the machine with the bypass lever in, so assuming the lever is going right in ( you may need to clear any grass away from the actuating lever on the gear box ) there has to be an issue with the hydo itself.
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on May 12, 2009
SOURCE: rear wheels locked
To move tractor you can remove one of the back wheels and remove key in shaft then replace wheel you should be able to move it .
Anonymous
  • Posted on Sep 07, 2009
SOURCE: sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Anonymous
  • 25 Answers
  • Posted on Mar 09, 2010
SOURCE: 4x4 will not engage when 4 hi button is pushed.
replace the encode motor or it could be the push button it self
Anonymous
  • 112 Answers
  • Posted on Jul 21, 2010
SOURCE: I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
Anonymous
  • 26 Answers
  • Posted on Oct 06, 2010
SOURCE: my troy bilt won't go in neutral
The Junior tiller does not have a neutral selection. In order to free wheel the tiller you have to remove the pins that go thru the wheel rim hubs and then it will roll without starting it. Hopefully the rims are not rusted to the wheel shaft.
Frank
2answers
2015 Husqvarna 46 inch cu drove onto the trailer got it home pulled the neutral bypass and now it's stuck in neutral will not move in any direction
so is a
Husqvarna YTH22V46 22-HP V-twin Hydrostatic 46-in Riding Lawn Mower
this is real name, and is mower not a car.
moved yah
jack it up and wiggle rear tires to free up box ?
brakes set?
My Husqvarna YTH2148 B yard tractor with auto transaxle and 48: mower deck is stuck in gear. Will not free wheel when shifted into neutral. How do I release? Thanks.
This fender shifted unit may need to be adjusted via shifter linkage. The linkage may not be finding neutral when the lever is in neutral. Try to move the lever easily into forward or reverse to see if the transmission can find neutral. If you can, then the linkage will need to be adjusted to compensate.
Why won't my Husqvarna Riding Mower go into gear? After having a tractor tire repaired and replacing the wheel and tire onto my Husqvarna Riding Mower, it will not go forward or into reverse.
It is possible that the neutral lever (free wheeling lever) has been actuated by pulling the lever out during the repair. For normal operation the lever should be pushed in.
Hope this helps?
Manual -See page 8 item (M)
http://www.husqvarna.com/ddoc/HUSO/HUSO2007_USen/HUSO2007_USen__532418916.pdf
1helpful
Husqvarna zero turn mower steering problems how to adjust neutral and balance steering
There is adjustments on both steering arms located under the seat. You can make the adjustments by lifting the unit's wheels off the ground and determine if the are "creeping" when the unit is running. Adjust the linkage until neither wheel creeps. Then the tracking can be adjusted by turning the screws located at the base of the steering levers.
Note, the levers do not return to neutral automatically.
1helpful
2answers
My ( 2008 Kawasaki Kx 100 ) kick-starter won't move down.. I tried Push Starting It and It's Seem To Lick The Back Tire... The GearBox Seem The Be Fine it's goes in neutral &' too gears 1-6 ... Also Moves...
Think you have simply frozen your piston from lack of proper fuel and 2 stroke oul mixture. Bike will move in neutral and with the clutch in, just won't kick or bumpstart ! Time for a top end rebuild my friend...good luck !
May 18, 2014 • Motorcycles
2helpful
I HAVE A 1990 LS 400 WHEN TURNING KEY NO CRANKING AND HAVE GOOD BATTERY POWER. NO POWER TO STARTER WIRE ON STARTER SELINOD.WHAT CAN IT BE
It could be a bad ignition switch or bad starter wire from the starter switch, or the PNP is not adjusted correctly:
Here are instructions on how to remove and replace the PNP, but read over it to understand how to adjust:
Park/Neutral Safety Switch REMOVAL AND INSTALLATION ES300 1993-94 Models
  1. With the ignition switch in the LOCK position, disconnect the negative battery terminal. If equipped with an air bag system, wait at least 90 seconds or longer before performing any other work.
  2. Raise and safely support the vehicle.
  3. Disconnect the Park/Neutral switch connector.
  4. Remove the clip from the shift control cable.
  5. Remove the nut and control cable.
  6. Remove the bolts and pull out the Park/Neutral switch. To install:
  7. Install the Park/Neutral switch and loosely install the bolts.
  8. Adjust the switch and torque the bolts to 48 inch lbs. (5 Nm).
  9. Install the control shaft lever.
  10. Install the control shaft cable and torque the nut to 9 ft. lbs. (13 Nm). Fig. 1: The transaxle control shaft lever has a nut and washer to retain it - 1993-94 ES300 54617.gif
    Fig. 2: Removing the Park/Neutral switch - 1993-94 ES300 54618.gif
  11. Install the clip to the shift control cable.
  12. Lower the vehicle.
  13. Connect the negative battery cable.
  14. Make sure the vehicle will start only in the PARK or NEUTRAL position.
1995-97 Models Fig. 3: Aligning the neutral base line and groove - 1995-97 ES300 293716.gif
Fig. 4: Park/Neutral switch removal and installation - GS300, LS400, SC300 and SC400 300569.gif
Fig. 5: Park/Neutral switch adjustment - GS300, LS400, SC300 and SC400 300571.gif
  1. With the ignition switch OFF, disconnect the battery cables, negative terminal first. Allow 90 seconds to elapse before performing any other work.
  2. Apply the parking brake fully and block the rear wheels.
  3. Disconnect the electrical connector from the Park/Neutral position switch.
  4. Remove the locknut and disconnect the control cable from the manual shift lever.
  5. Remove the clip from the holding the control cable to the bracket.
  6. Remove the nut, washer and the manual shift lever from the manual valve shaft.
  7. Using a flat bladed tool, bend the lock washer back away from the nut.
  8. Remove the nut and lock washer from the Park/Neutral switch.
  9. Remove the two bolts and the Park/Neutral position switch. To install:
  10. Install the Park/Neutral position switch to the manual valve shaft. Leave the two bolts loose at this time.
  11. Install the lock washer and nut. Torque the nut to 61 inch lbs. (7 Nm).
  12. Using a flat bladed tool, bend the lock washer over the nut to secure the nut in place.
  13. Adjust the Park/Neutral as follows:
    1. Install the manual shift lever to the Park/Neutral switch and set the shift lever to the neutral ( N) position.
    2. Align the groove and the neutral basic line on the Park/Neutral switch.
    3. Hold the Park/Neutral switch in this position and tighten the two bolts to 48 inch lbs. (5 Nm).
  14. Install the manual shift lever with washer and nut.
  15. Install the control cable to the manual shift lever and install the nut. Torque the nut to 11 ft. lbs. (15 Nm).
  16. Install the control cable to the bracket by installing the clip.
  17. Connect the electrical connector to the Park/Neutral switch.
  18. Lower the vehicle and check the vehicles shifting positions.
  19. Connect the negative battery cable to the battery.
  20. Verify that the vehicle only starts in PARK or NEUTRAL.
  3. If necessary, remove the front exhaust pipe.
  4. Disconnect the neutral start switch connector.
  5. Remove the control shaft shift lever.
  6. Pry off the washer and remove the nut.
  7. Remove the bolt and pull out the neutral start switch. To install:
  8. Install the Park/Neutral switch and loosely install the bolt.
  9. Adjust the switch as follows:
    1. Loosen the neutral start switch bolt and place the shift lever in the N position.
    2. Align the groove and the neutral basic line.
    3. Hold in position and tighten the bolt to 9 ft. lbs. (13 Nm).
  10. Install the nut and washer.
  11. Install the control shaft shift lever.
  12. Connect the electrical connector.
  13. Install the front exhaust pipe. Torque the front nuts to 46 ft. lbs. (62 Nm). Torque the pipe support bracket to bolts to 32 ft. lbs. (43 Nm). Torque the No. 2 front exhaust pipe to the front exhaust pipe bolts to 32 ft. lbs. (43 Nm).
  14. Lower the vehicle.
  15. Connect the negative battery cable to the battery.
  16. Verify that the vehicle will only start in the N or P positions.
Maybe try to press the brake pedal and run the gear shift throughout the full range of gears while the car is on level ground, and retry the starter to see if there is a faulty PNP adjustment.
Try to start in Neutral not Park, and jiggle the gear shift back and forth to see if the PNP is not adjusted right.
Good luck on this repair.
2helpful
2answers
How to replace neutral saftey switch on a 1980 cadillac deville?
Use like reference guide for GM Cadillac 1967-1989 Repair Guide Neutral Safety Switch - REMOVAL & INSTALLATION
All Except 1985-89 Eldorado and Seville
See Figure 1
The neutral safety switch prevents the engine from being started in any transmission position except Neutral or Park. The switch is located on the upper side of the steering column under the instrument panel on column shift cars, and inside the shift console on floor shift models.
  1. Remove the console for access on floor shift models.
  2. Disconnect the electrical connectors.
  3. Remove the neutral switch.
To install:
  1. Place 1967-70 column shift lever models in Drive, and 1971 and later models in neutral. Locate the lever tang against the transmission selector plate on column shift models.
  2. Align the slot in the contact support with the hole in the switch. Insert a 3 / 32 in. (2.38mm) diameter pin in place. The switch is now aligned in Drive position.
1973 and later neutral safety switches have a shear-pin installed to aid in proper switch alignment so that insertion of a pin is unnecessary. Moving the shift lever from Neutral shears the pin.
  1. Place the contact support drive slot over the drive tang. Install the switch mounting screws.
  2. Remove the aligning pin. Connect the electrical wiring, and replace the console.
  3. Set the parking brake and hold your foot on the service brake pedal. Check to see that the engine will start only in Park or Neutral.
Fig. 1: Installation of a common neutral safety switch
ADJUSTMENT
See Figure 2
1974 and later cars do not have a neutral safety switch. Instead, these cars have an interlock between the lock and the transmission selector, which is non-adjustable.
  1. Place the shift lever in Neutral.
  2. Move the switch until you can insert a gauge pin, 3 / 32 in. (2.38mm) diameter, into the hole in the switch and through to the alignment hole.
  3. Loosen the switch securing screws. Remove the console first, if necessary.
  4. Tighten the screws and remove the pin.
  5. Step on the brake pedal and check to see that the engine will only start in Neutral or Park.
Fig. 2: Adjustment of a common neutral safety switch
See Figure 3
All neutral safety/back-up light switches come with a small plastic alignment pin installed. Leave this pin in place.
  1. Place the shifter assembly in the Neutral position.
  2. Remove the shifter lever-to-switch nut and the lever.
  3. Disconnect the electrical connector from the neutral safety/back-up light switch.
  4. Remove the neutral safety/back-up light switch-to-transaxle bolts and the switch from the vehicle.
To install:
  1. Position the shifter shaft in the Neutral position.
If using an old switch or the plastic pin (new switch) is broken, install a3/32in. (2.38mm) diameter pin gauge (drill bit) into the neutral safety/back-up light switch; the switch is then locked into its Neutral position.
  1. Align the flats of the shifter shaft and the neutral safety/back-up light, then, align the switch-to-tang on the transaxle. Torque the switch-to-transaxle bolts to 22 ft. lbs. (30 Nm). Remove the pin gauge.
  2. To complete installation, reverse the removal procedures. Make sure that the engine starts only in the Park and Neutral positions.
Fig. 3: Neutral start and back-up lamp switch - 1985-89 Eldorado and Seville
Hope help with this (remember rated and comment this). Good luck.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
