How to replace rotted 1 1/2 inche long pip, the gooseneck water hoses is beneath the starter and connects to the water pump housing
SOURCE: impeller - whirlpool duet front load
youll def need to replace the drain pump assy part number 280170
SOURCE: coolant leak at the top radiator hose
the plastic radiator tank that the hose nipple is part of can be replaced by any radiator repair shot for about $75-100
SOURCE: How to replace a water pump on a 1999 dodge
so i just replaced my water pump today on the same car, mine is a 5.9 magnum. I drained the whole system before i started working on it, next you have to take off the fan, if you look on the inner side of the fan there is a big nut there, in order to loosen that i put to bolts into the holes on the water pump pulley and used a thin screwdriver for leverage, while putting pressure on that, i loosened the nut, be careful not to slip cuz those fan blades are dangerous. but once you have removed that nut from the pulley take out the four bolts holding on the housing, pull the fan and the housing out at the same time. next remove the belt, after that is done, disconnect the hoses from the water pump, there are three, one on each side and one on top. there are a total of eight bolts holding the pump on, keep track of them because they are different sizes. But that is how i removed mine. It was all farely simple i am a girl and i managed to do it so i think you should be fine. Hope it works for you becuase it didnt work for me, i now think that it is my head leaking, if you know anything about that let me know.
SOURCE: Poulan Wild Thing 18 Inch replace starter spring?
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
SOURCE: Replace Fuel Filter on 2006 Chevy Aveo Hatchback
If the fuel filter is mounted inside the fuel tank at the pump it does not need replacing and is a permanent filter. All you have to do it follow the fuel lines from the fuel tank to the engine. If the filter is mounted in the fuel line you will find it.
