SOURCE: fuel ratio for homelite ut10829
the ratio should be 25 to 1 so 250 mls of oil for 1 litre of petrol
SOURCE: Need a Manual for HomeLite Leaf Blower Vacuum
Most 2 stroke engines.......99% now use 50 to 1 mix in the fuel.
Others are close to this ratio.
Older....over 20 to 30 years old ........that may have had 20 to 1 ....or other ratios run happily on a 50 to 1 ratio using the newer 2 stroke oils.
And......BONUS.......they have increased engine life because of reduced semi burnt oil build up caused by "too much oil".......particularly around the rings on the piston(s) etc.
SOURCE: I am looking for a homelite super 2 service manual
The factory manual states: Recommended First choice is Premium Homelite 32:1 Motor oil(SAE-40) in ratio 1 part oil to 32 parts gasoline (1/4 pint per U.S. gallon of gas or 3% oil)
Second Choice: Homelite 16:1(SAE-30) Motor oil or any motor oil for air-cooled 2-cycle engines in ratio of 1 part oil to 16 parts of gasoline (1/2 pint oil per U.S. gallon gasoline or 6% oil
The newer models are 50:1 yours is 32:1
I have that saw. The manual states if you are using Homelite 2 -cycle oil read and follow the instructions on the package. If you use other than Homelite oil use 16 parts gasoline to 1 part 2- cycle oil, 1 gal / 8oz
