I tried hooking my Nintendo 64, my Wii, and my Wii U using the composite cables. I put the channel on AUX, and nothing shows up. Am I doing something wrong, or I just can't play games on the TV. Thank you in advance.
SOURCE: can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
SOURCE: No Aux Channel but I have the yellow and White plugs in the front!
Take out the channel up button and use a small, long object (like a pencil or pen) and repeatly press the button under until AUX comes up.
SOURCE: SNES doesn't display?
The CIC chip, also known as lock out chip, may have gone bad. Here is a quote from a site I found.
"Every SNES control deck has a regional lockout chip (known as a CIC),
as does every original SNES game cartridge. Before a game is loaded,
the console will attempt to communicate with the CIC chip on the game
cartridge. If the CIC chip doesn't respond or does not correspond with
the consoles CIC, the console won't load the game. In most cases, a
black screen is displayed."
http://www.chronicgames.net/articles/snes-museum.aspx
Yea basically I am having the same prob with my system and I am trying to fix it. Ill let ya know if i figure it out
SOURCE: My nintendo 64 channel is not 3/4 ----what is it then?
Are you using the a/v cable from the N64 to the tv? The red and yellow cables?
If so then you need to change your TV to one of the video channels like video 1, video 2, video 3, it would depend on what input you have your N64 hooked up to. if your using an rf connector then make sure you are using channel 3 and you might have to make sure on the rf connector that its also set to 3.
SOURCE: Nintendo 64 game console, TV says no signal,
This usually indicates that you have the video cables connected incorrectly. The T.V. is just telling you that it's not getting any video signal from the console.
Check your connections, and if all looks well, perhaps the consoles video outputs or cable is shot.
Good luck.
