SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
SOURCE: how to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
SOURCE: Thread gets stuck around a knob on Necchi 536 FB sewing machine
I'm guessing you would have loosened the tension? Is there grit or something sticky (dirty oil) stuck between the tension discs?
Testimonial: "Very helpful suggestions. Cleaned around the upper tension regulator and adjusted top and bobbin tension today. So far, so good. Thanks. "
