SOURCE: Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
SOURCE: write a mathematical model representing the total monthly cost
Mathematical Model for the problem:-
Option1: C=42+5*x
Option2: C=0+ 8.5*x
Thanks
Zulfikar Ali
[email protected]
09899780221
SOURCE: Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
SOURCE: content error loading netflix on
Yes it is most likely to be a firmware bug. Did not understand what you meant by "have sony sending firmware update on usb key" though. Can you please clarify this?
SOURCE: We are using Netflix instant
Netflix doesn't cost much but you do have to pay for it. $7.00 a month for streaming and 8.00 if you want DVD's. If you are a memeber Netflix will help you @ netflix.com. Your tv has to be hooked to the internet.
