2002 Jeep Liberty oil pressure light comes on in cold
Chrysler mounted the oil sensing unit on these motors directly above the oil filter. It is very easy to accidently hook the sensing unit with the oil filter wrench and crack or break it. For anyone whose oil light problem developed right after an oil change, this may be the problem. To change the unit, pry up the plastic retaining clip with a screw driver and unplug the wire harness. If the plastic part of the sensor is broken, (or if you break it to facilitate easy removal), you can remove the sensor with a 27mm socket. Once you have removed it, use a piece of CLEAN pipe cleaner to insure the hole isn't plugged with sludge which could also cause the oil light to come on. Screw in the new unit finger tight, then snug up with a WRENCH. You cannot use the socket to tighten it as it would damage the plastic part of the new sensor. Plug the wire harness back on, then start the engine to make sure it doesn't leak oil around the new unit.
