SOURCE: Attaching a plug in cord to a philips Electric Steam Iron
i need a new wire--mine had a short in it--how do I go about repairing it?
SOURCE: I need to replace the power supply cord on my Rowenta DX8600 iron
Hi, you need not to disturb yourself too much, just take the iron to any electronic repairer or electrician around you and they will replace the cord for you. They have the screw drivers for all types of screws...
Take care
SOURCE: Rowenta Steam Iron DG5030; Iron drips water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
SOURCE: instructions for steam clean on B&D iron
http://useandcaremanuals.com/pdf/D1200,D1500,D1600,D1650997.pdf
Or http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Hope this helps you.
SOURCE: Where do I obtain a tool to unscrew the screws on
buy a set of security bits from an electronic supplier.Can be bought in sets of 24 most used tamper proof bits that will fit into a multi screwdriver.
