SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
SOURCE: Leaks water out overnight
I bet it leaks from the back, right? If it does, it has the same problem as my dad's.
You have a leak in the back of the holding tank. Fill it up, turn it around, without plugging it in, and watch for the water leak. If it's in a spot that you can see, then use some caulking to seal the leak. That should work. If not, it is leaking out from inside the plastic holding tank. Not much you can do but buy a new one.
SOURCE: delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
SOURCE: my cuisinart coffee maker leaks
1. Purchase (1) a couple of feet of 3/8" ID by 5/8" OD temperature resistant silicone tubing from a beer/wine-making supplier, or online through Ebay, and (2) a couple of hose clamps big enough for the tubing.
2. Unplug the coffee maker and turn it upside down on some old newspaper.
3. Using a T10 Torx screwdriver, remove the 4 screws that attach the the bottom plate of the coffee-maker, and remove the bottom plate.
4. Unclamp the two orange/red hoses from the C-shaped heater, and carefully pull/remove the other end of the two hoses. One hose is a water intake hose from the water tank to a C-shaped heater element, while the other hose is water outlet hose that goes from the C-shaped heater element to the sprinkler assembly.
5. Carefully remove the small plastic stop check valve from the water inlet hose end close to the C-shaped metal water heater; and take care to not drop/lose the little round plastic ball inside the plastic stop/check valve, while noting which way the stop-check valve is oriented in the hose.
6. Cut two pieces of your food-grade / temperature resistant silicone tubing that are the same length as the old hoses.
7. After reinstalling the stop-check valve in the new inlet hose/tubing, reinstall the two sections of hose/tubing, and use two hose clamps to attach the new tubing to the C-shaped water heater.
N.B. Remember that the stop check valve s/b oriented such that hot water in the C-shaped heater element can't go back to the water tank.
7. The ends of the hose that attach to the C-shaped metal water heater s/b clamped, while the other ends just push onto the water tank and sprinkler assembly with a with a little pushing and twisting.
See http://www.cocosvariety.com/2011/11/fixing-cuisinart-coffee-maker-alternate.html , as that is the original information source for this posting and the image below. i.e. Credit goes to Coco's Variety !.
Also, in the image below, the hose on the left is the water inlet hose, while the hose on the right is the water outlet hose.
