The rev limiter on a 1995 Mercury 115 hp 2-stroke outboard engine is typically located within the engine's electronic control module (ECM). The exact location of the ECM can vary depending on the specific model and configuration of the engine, but it is typically located near the engine's ignition system. If you are unsure of the location or operation of the rev limiter, it is recommended that you consult the engine's owner's manual or contact a qualified marine mechanic for assistance.
SOURCE: johnson 4 stroke 115 hp will not start. fuel
Sounds like and injector problem to me. If it was a 2 stroke I'd tell you to pull the carbs and clean them ,but EFI is a whole different story. Most certaintly a fuel problem, most likely injector related, you'll most likely need to go see a marine mechanic with the proper equipment to analyze, rather than start replacing parts you may not need.
SOURCE: impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
SOURCE: I have a Mercury 7.5 hp 2 stroke engine,At high
No, you should always have water shooting out of the tell-tail port at all engine speeds. The impeller in the water pump assembly is worn and will need to be replaced. It seems like it compensates with higher revs,but can not provide the water volume at low revs.
SOURCE: I have a 2005 Merc
I don't know much about these boats, but it sounds like perhaps a "kill-switch" is being activated when it's shifted to neutral. The following web blog discusses a similar problem, and explains how the boat goes from 4 cylinders to 2 when idling, and attributes this problem to a carburator issue:
http://forums.iboats.com/showthread.php?p=917249
In the following blog, Dan Hardy reported he changed an electronic controller, and that fixed his problem:
http://www.thenextbite.com/node/9632
You might contact Mercury or an Outboard Dealer to see what they think...a mechanic would have experience with this issue, and could probably tell you what's most likely the problem.
Good luck, and hope this helps.
