Master
- Posted on Feb 23, 2023
Re: How to get the cover off of a mn star fuse box on a...
To remove the cover of a MN Star fuse box on a Premier pontoon, you can follow these steps:
- Locate the MN Star fuse box on your Premier pontoon. It is usually located in the helm area or in a console.
- Identify the locking mechanism that holds the cover in place. It may be a latch or a screw that needs to be unscrewed.
- If it is a latch, press the latch and lift the cover. If it is a screw, use a screwdriver to unscrew it and then lift the cover.
- If the cover is still stuck, check for any additional screws or latches that may be holding it in place.
- Once the cover is removed, you should have access to the fuses and wiring inside the box.
- When putting the cover back on, make sure it is properly aligned and locked in place to ensure proper protection of the fuses and wiring.
If you are still having difficulty removing the cover or have any concerns, it may be helpful to consult the owner's manual or seek assistance from a professional.
