I have a karcher K2.89. It works fine apart from the detergent reservoir - nothing seems to pass through and we' ve lost the manual. Can anyone please advise?
manualslib has a download option you have to tell it you are not a robot and may have a capta picture test. click on a page of the manual and you will see the download button at the top of the page .
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to
REMOVE the high pressure Sprayer so that all you use is the Trigger
Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so
you will then need to REATTACH the SPRAYER into the hand gun to work
with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known
as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au
site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just
like I did and had a great problem trying to find a link as Karcher
doesn't recognize the Model No: as Winner 10 or 11.
The first thing to do is check the nozzle setting on your spray lance. The nozzle setting is adjustable (by twisting it) and, if it's set to high pressure, cleaning fluid will not be drawn up from the reservoir. Cleaning fluid will only be drawn from the reservoir when the nozzle is set at low pressure. (Even at the low pressure setting, this problem can occur if you use an extension high-pressure hose.)
You say the machine has never been used, so the nozzle setting is the most likely cause of your problem. Other possible causes are highly unlikely to occur in a new machine. If adjusting the nozzle doesn't help, I suggest you contact the dealer from whom you bought the machine.
I hope this helps. Your feedback is valuable to me so please remember to rate this response.
