Hi, try this:
1. Try and restart the tablet. Sometimes it is that simple.
2. Update the firmware and any apps that need updating on the tablet.
3. If the problem persists, check your time and date on the tablet to make sure it is correct.
4. Should none of the former work...
a. Clear out the WiFi data on the tablet.
b. Reboot the modem/router.
c. Once the modem/router is fully 'up' again, reboot the tablet and re-input the WiFi data.
5. Check your internet connection. It may be what is going in and out rather than the tablet.
6. Make sure you have "Data" turned off on the device when using "WiFi" (that is if you have a plan with data through your tablet). If you don't make sure it is turned off, the device can keep trying to switch to "Data" when you try and use "WiFi".
7. Now, if you are still having the problem at this point, and you are sure it isn't the modem/router that is the problem. Then you may wish to try a "Hard Reset" of the device. However, I really suggest saving this as a last option (or last before parts repair/replacement).
SOURCE: wifi - packard bell laptop
I sometimes have the same problem and usually it's because the router somehow looses connection with the laptop. You may require a stronger router/different kind of router. Have you tried to move the location of your router first to see if that could be one of the problems ?
Hope this works for you.
SOURCE: Packard Bell WiFi Switch on
Kindly check your spec as it doesn't contain built in WiFi however you can add external Wireless card
Good Luck
SOURCE: NEED TO DOWNLOAD CD ROM DRIVER FOR MY PACKARD BELL IPOWER 5264 LAPTOP
Hey there SHAMESTAR, Not an easy find, but here is the location:
http://support.packardbell.com/global/item/index.php?m=home&pn=P730012001
If the link doesn't work, just copy and paste. Good Luck. Let me know if you have any problems!
SOURCE: packard bell registration message
There is a solution for this problem, but you have to be very computer orentated to correct it. First look in the programs listing under startup and see if there is a link there for the PacBell auto start when the computer tarts each time it is turned on. If there is a link there right click on it and delete the shortcut from the startup menu. restart the computer and see if it is still there. if so go back and look in the startup menu selection and see if it has reappeared. If it has then you will have to shut off the windows auto recovery option so it will not replace the missing file when the computer is restarted. Now if this does not work, you will have to get someone that is familiar with the registry files. You do not want to go probing around in there or you may just shut down tour computer permanently. A professional will have to go in and search for the file entry that controls the option and then delete the corresponding registry entries. Regards, rcampsr
